Drive axle stuck, help!!
Old Jan 18, 2004 | 01:38 AM
djurbang's Avatar
Default Drive axle stuck, help!!
I'm doin a re-ring project and while getting the engine out I came across a problem. The passenger drive axle is still stuck on one stud connecting to the lower steering knuckle arm. I've already removed the tie-rod from the upper steering knuckle arm, but the lower stud is giving me problems now. On the driver's side, all I did was pry around the edges and pull the axle right off but me and 3 other guys have tried everything to get that other arm disconnected and nothing as of yet. This is the very last part I need to come out for the engine removal, so if anyone could help it would be greatly appreciated. I can provide pictures if need be. PLEASE HELP!! LOL
Old Jan 18, 2004 | 05:28 AM
slow_dx's Avatar
Default Re: Drive axle stuck, help!! (djurbang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djurbang &raquo;</TD></TR><TR><TD CLASS="quote">I'm doin a re-ring project and while getting the engine out I came across a problem. The passenger drive axle is still stuck on one stud connecting to the lower steering knuckle arm. I've already removed the tie-rod from the upper steering knuckle arm, but the lower stud is giving me problems now. On the driver's side, all I did was pry around the edges and pull the axle right off but me and 3 other guys have tried everything to get that other arm disconnected and nothing as of yet. This is the very last part I need to come out for the engine removal, so if anyone could help it would be greatly appreciated. I can provide pictures if need be. PLEASE HELP!! LOL</TD></TR></TABLE>
Djurbang,
What car is this on?
Am I correct in reading the above as "I couldn't separate the lower control arm from the balljoint." ?
On my 2000 hatch, I had to remove the lower control arm balljoint, not the upper or the steering tie rod. To disconnect it, I used a balljoint puller. It looks like a U with a screw in the middle. You fit the 'fingers' of the U over the base of the steering knuckle and twist the screw against the bottom of the balljoint, which will force it out of the LCA.
There is also a guy on here, that whenever I post this advice in a thread suggests that you just hit something (LCA?) with a really big hammer, which will just pop the balljoint out, but I've never done it that way, so I can't explain it to you. He may chime in here at some point and give you some tips. If you search for this, you might find his advice as well.
I also had to disconnect the damper fork from the lower control arm.
HTH.
Old Jan 18, 2004 | 07:38 PM
djurbang's Avatar
Default Re: Drive axle stuck, help!! (slow_dx)
Thanks, I figured it out earlier today, instead of a balljoint puller, which believe it or not is quite hard to locate at hardware stores, i did it manually with one of those balljoint forks. Thanks for the help...
...oh yeah, the hammer thing was my first choice, didn't work, lol
louevilhatch
16
Dec 26, 2011 04:09 PM
DarkBB4
Apr 22, 2007 09:29 PM
B18CYAAA
Jan 9, 2007 05:29 PM
Toda Built
Jan 18, 2004 03:09 PM
Malice
Jun 21, 2002 09:08 PM
