4-Speed (std) to 5-Speed (DX) Shifter ?
Old Jan 17, 2004 | 07:29 PM
Kyoji's Avatar
Default 4-Speed (std) to 5-Speed (DX) Shifter ?
Right now I'm swapping out my blown D15B1 out of my '90 STD HB and putting in a DX engine (D15B2) that I got for cheap. I also got the 5-speed transmission with it and was considering putting it in too.
What needs to be done to the linkage and shifter to make this work? Everything the same, just with a different gate thing?
Also, do the STD axles and stuff pop right in to the DX tranny?
I searched and came up with mixed results about how plug and play it is... Help clear this up.
Old Jan 17, 2004 | 07:49 PM
JonGP4's Avatar
Default Re: 4-Speed (std) to 5-Speed (DX) Shifter ? (Kyoji)
u need to move the rear trany mount to the other set of bolt holes, when you look you will see what i'm talking about.. everything else bolts up like stock.. u might need to switch to the 5spd trany mount as well
Old Jan 17, 2004 | 10:39 PM
Louie B.'s Avatar
totally plug and play.... use the std axles.
Old Jan 17, 2004 | 10:40 PM
payneth's Avatar
Default Re: 4-Speed (thumpu77)
good luck keep us posted
Old Jan 18, 2004 | 06:00 AM
Cory man's Avatar
Default Re: 4-Speed (OneSlowEF)
I did this swap in a friends car and everything bolted right up. No moving anything or getting different mounts. The std axles will work just fine. The D15b2 and 5 spd makes the car much quicker. hth
Old Jan 18, 2004 | 10:02 AM
Lo-Buck EF's Avatar
Default Re: 4-Speed (Cory man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cory man &raquo;</TD></TR><TR><TD CLASS="quote">I did this swap in a friends car and everything bolted right up. No moving anything or getting different mounts. The std axles will work just fine. The D15b2 and 5 spd makes the car much quicker. hth</TD></TR></TABLE>
same here. i did this swap and nothing had to be moved. when i put my eg sohc in, i had to change teh drivers side mount. but thats it.
-spenc
Old Jan 18, 2004 | 12:08 PM
sohcvtec66
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoji &raquo;</TD></TR><TR><TD CLASS="quote">Right now I'm swapping out my blown D15B1 out of my '90 STD HB and putting in a DX engine (D15B2) that I got for cheap. I also got the 5-speed transmission with it and was considering putting it in too.
I searched and came up with mixed results about how plug and play it is... Help clear this up.</TD></TR></TABLE>
HERE i just got done talking about all this....https://honda-tech.com/zerothread?id=458097
Old Jan 18, 2004 | 01:23 PM
Kyoji's Avatar
So far this is everything I wanted to hear. The less work the better.
One question though, will the 4-speed shifter bolt right up? If so, how will it go into 5th gear? I haven't got to that point yet, but I'd like to know how big of a hassle this will be. In my mind it doesn't seem like it would work without getting parts off the 5 spd shifter and linkages. Or am I just not thinking of something?
Thanks.
Old Jan 18, 2004 | 01:56 PM
Machine1's Avatar
Default Re: 4-Speed (Kyoji)
One question though, will the 4-speed shifter bolt right up? If so, how will it go into 5th gear? </TD></TR></TABLE>
The 5th gear is in the transaxle itself and not the shifter assembly. There are no gates or anything where the shifter is. You shouldn't have to even remove your shifter. Just bolt the old linkage to the new tranny.
Kyoji's Avatar
Default Re: 4-Speed (Machine1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Machine1 &raquo;</TD></TR><TR><TD CLASS="quote">
The 5th gear is in the transaxle itself and not the shifter assembly. There are no gates or anything where the shifter is. You shouldn't have to even remove your shifter. Just bolt the old linkage to the new tranny.</TD></TR></TABLE>
Sweet, exactly what I wanted to hear! Thanks alot!
Old Jan 19, 2004 | 01:00 AM
sohcvtec66
Guest
Posts: n/a
WOW....
Old Jan 19, 2004 | 06:15 AM
Kyoji's Avatar
Default Re: 4-Speed (sohcvtec66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec66 &raquo;</TD></TR><TR><TD CLASS="quote">
WOW....</TD></TR></TABLE>
...as in is there a gate blocking where 5th gear would be.
Red_ED8
Oct 13, 2005 02:16 PM
BigDawwg6969
Oct 12, 2004 08:38 PM
91sihatchback
Jul 12, 2004 07:56 AM
projectcrx
Mar 26, 2003 09:57 PM
zcivicz
30
Apr 15, 2002 02:29 PM
