ZC distributor seized, Si distributor work?
Old Jan 17, 2004 | 09:55 AM
b17gsr's Avatar
Default ZC distributor seized, Si distributor work?
Ok, 88 CRX Si with a DOHC ZC. Car stalled a few days back, got it towed to my place thinking it was frozen, or bad ignitor.
Pull the cap off, the rotor is melted and about 45 degrees off the timing.
We replace it with another one, get the CRX running, 5 minutes later it stalls again, same problem.
This time I pulled off the ZC distributor thinking maybe the shaft is loose. Well i can't turn the shaft (cam side) without using a wrench. The old D16A6 one easily turns by hand.
Anyone use an Si distributor on a ZC successfully?
Old Jan 17, 2004 | 10:00 AM
crxgator's Avatar
Default Re: ZC distributor seized, Si distributor work? (b17gsr)
you cant use the Si with the ZC...you need an 88-89 integra...
Old Jan 17, 2004 | 10:11 AM
b17gsr's Avatar
Default Re: ZC distributor seized, Si distributor work? (crxgator)
Anyway of rebuilding it myself? Could it be a bearing or something?
Old Jan 17, 2004 | 11:15 AM
Sikocivic's Avatar
Yes you can run the Si dizzy. Only 1 of the bolts line up and you have to repin the plug back to the round plug. This should only be done for a short time(I drove mine for a week) while you are getting a new dizzy. If you run it too long like that you will burn out the bearings because it sits in there funny. I would just get a new one from a 88-89 Teg.
Old Jan 17, 2004 | 11:24 AM
cottagecreep's Avatar
Default Re: ZC distributor seized, Si distributor work? (Sikocivic)
http://www.geocities.com/civiczc/zcwire.html
This link may help, I havn't really checked it out though.
roterx7
Feb 18, 2006 03:16 PM
Ahks
Feb 11, 2006 08:24 AM
SiR_Injected
Nov 24, 2005 11:54 AM
h22_crx
Oct 6, 2005 11:16 AM
kickz
Jan 27, 2002 06:05 PM
