What does it take for RSX-S seats into a 95 civic hatch?
Old Jan 17, 2004 | 09:41 AM
gdrum's Avatar
Default What does it take for RSX-S seats into a 95 civic hatch?
Ive read about this with integras but not with civic's, has anyone done this or what can be done. Could I just redrill the bottom of the car and bolt the stock rsx rails into those holes or what. Thanks
Old Jan 17, 2004 | 09:50 AM
JDMlyfestyle's Avatar
i wanna know to. and hello fellow hoosier
Old Jan 17, 2004 | 09:53 AM
skip.two's Avatar
Default Re: What does it take for RSX-S seats into a 95 civic hatch? (gdrum)
i thought honda would make them the same as before. either they're direct bolt on, or you just swap the rails with the ones of the car that they are going into(ex: 95 civic hatch).
Old Jan 17, 2004 | 09:56 AM
95cxhatch's Avatar
Default Re: What does it take for RSX-S seats into a 95 civic hatch? (jL iLLuZiOnz 9)
if they fit into an integra, they should bolt in the civic the same way....shouldn't they?!.......just swap rails like ws already said and they should fit in there.....good luck!
Old Jan 17, 2004 | 10:03 AM
ya that is correct. I just remembered when i had my teg seats. those were a straight bolt up. so i assumer to use the same process as they did in a teggy
Old Jan 17, 2004 | 11:10 AM
gdrum's Avatar
Default Re: (JDMlifestyle)
well i read modding was required for integra with rsx seats but im not sure i just need someone who has done it or seen it done and what they had to do
Old Jan 17, 2004 | 12:39 PM
egizzle8
Guest
Posts: n/a
Default Re: (gdrum)
When you guys say "swap rails" does that include the unbolting the upper back part of the seat, or am I just retarded. Aren't(it's not a word but you guys know what I'm talking bout!) the seat belt part and everything else connected to it or does it bolt apart somewhere?
Old Jan 17, 2004 | 01:11 PM
twinbros's Avatar
The RSX seats will NOT bolt up. You can't even swap rails or pans. Best thing to to is have someone fabricate/mod the rsx rails to bolt to your eg. By the way, no even the seat belt release thing is compatable. Good luck.
Old Jan 17, 2004 | 01:20 PM
95cxhatch's Avatar
Default Re: (twinbros)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinbros &raquo;</TD></TR><TR><TD CLASS="quote">The RSX seats will NOT bolt up. You can't even swap rails or pans. Best thing to to is have someone fabricate/mod the rsx rails to bolt to your eg. By the way, no even the seat belt release thing is compatable. Good luck. </TD></TR></TABLE>
ya.... the seatbelt was the only major thing i was thinking about that could be a problem
Old Jan 17, 2004 | 02:01 PM
tshaw's Avatar
Hello fellow hoosiers
(lol sorry had to do that also)
Old Jan 17, 2004 | 09:50 PM
gdrum's Avatar
Default Re: What does it take for RSX-S seats into a 95 civic hatch? (tshaw)
Cant i redrill holes in floor and use stock rsx rails to bolt in.....use steal plates to level it out or whatever as spacers....then swap my eg seatbelts over .....thatd work and not to hard i dont think...
Old Jan 17, 2004 | 09:59 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
This would be the only correct answer in regards to this post. One might try the s2000 trick by removing the entire bottom pad of the seat installing a civic/integra one.
Old Jan 17, 2004 | 10:01 PM
95cxhatch's Avatar
well if you don't mind rdrilling floor holes in your car.....give a whirl.....you'll probly be able to do it without too much hassle
Old Jan 18, 2004 | 06:55 AM
gdrum's Avatar
Default Re: What does it take for RSX-S seats into a 95 civic hatch? (95cxhatch)
Yea i was wondering if the s2k pan switch trick worked on these......its possible option to i bet.
Old Jan 18, 2004 | 07:27 AM
hondaeg95's Avatar
Default Re: (gdrum)
my friend has them in his 97 civic, they dont bolt directly in you must mod to make them work. the two back bolt up but he just had someone weld a adaptor on to make the fronts bolt down.
Old Jan 18, 2004 | 12:47 PM
Cynical 1's Avatar
Bump for Muncie and BSU.
Old Jan 18, 2004 | 06:07 PM
gdrum's Avatar
Default Re: What does it take for RSX-S seats into a 95 civic hatch? (Revolveu2)
Yea i live in muncie and go to BSU ......represent! ha
Old Jan 20, 2004 | 05:45 PM
tshaw's Avatar
bump for muncie haha i live in anderson and have friends at ball state so bump for ball state
_em2_
Honda Civic (2001 - 2005)
24
Sep 6, 2007 11:28 AM
Vitesse
May 11, 2006 11:28 AM
YoungChrisEG
13
Apr 20, 2005 12:11 PM
TCvtec95
Mar 20, 2004 09:28 AM
armrslr
Aug 12, 2003 09:41 PM
