1995 Integra w/ B20 Vtec 240hp /Brand New Engine
Here is what is in my 1995 Acura Integra LS:
84.5MM Dart Block with
Eagle 89mm Knife edged crank,
Eagle Rods .137 longer
Endyn 13.5:1 Pistons w/ pin moved up (R/S ratio 1.60)
ITR tranny w/ ATS 1, 3, 4 and 5 Gears and ATS LSD
AEM EMS Fuel Management System w/Techedge WB O2 sensor
Portflow Head w/Portflow valve retainers
Ferrea Stainless Valves
Toda Spec C cams, Valve springs, Oil pump gear, Clutch and Flywheel
Raxle Road Race Axles
Jenvey ITB's
Endyn RW Pistons @ 13.5:1 and block breather kit
Crower Rods
Z10 Radius Bars
RC Eng 440cc Injectors
Hytech Big Bore Header
Hytech Twin Loop exhaust
AutoPower Full Welded Cage
FastBrakes Wilwood Brakes
Koyo Radiator
Setrab 25 row Oil Cooler / remote filter
Walbro GSS342 Fuel Pump
Zeal Super Function 14k/10k
Recaro SPGs (2)
Sparco 5 point Harness
Volk TE37 15x7 with Kuhmo Ecsta V700 R compounds
Kosei K1 15x7 with snow tires and a set of unsummer street tires also
many many more upgrades........
MAKE OFFERS .... I will ingnore any offer for under $16K
I will not consider any trades- unless its for a Lotus Elise or '95+ 911
http://www.imagestation.com/album/?id=4290452555
Modified by Christian at 6:57 PM 1/17/2004
Jenvey ITB's
Crower Rods
Z10 Radius Bars
Koyo Radiator
Recaro SPGs (2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn »</TD></TR><TR><TD CLASS="quote">killer man! but seriously, 16k?
dont be offended..</TD></TR></TABLE> No offense taken, its obvious you don't even knew what half the **** in my car is .... Next time you should keep your 50cents to yourself.
....... unless of course you want to show me a similar or better setup for less.
Modified by Christian at 2:31 PM 1/20/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecdeath »</TD></TR><TR><TD CLASS="quote">did payn build that ?</TD></TR></TABLE> Nope it was built by DRT in NYC
great car awesome power and handling, if i had the loot id buy it in a heart beat.
