Difference Between Toda Bs & C's?
Old Oct 1, 2001 | 06:47 AM
slowcivic's Avatar
New User
Default Difference Between Toda Bs & C's?
Does anyone have any experience with Toda Spec. B and C Camshafts? What perfmormance gain would I get if I used Cs instead of Bs in a 95 GSR all-motor application? Also, could anyone tell me the powerband difference between the two?T.I.A.
Old Oct 1, 2001 | 11:25 AM
slowcivic's Avatar
New User
Default Re: Difference Between Toda Bs & C's? (slowcivic)
Please Help. Thanks.
Old Oct 4, 2001 | 08:37 PM
Incognito's Avatar
Don't bother putting in Toda Spec C's if you're not running high compression pistons, some kind of fuel system upgrade, and have a crazy header. The B's are probably better overall. I run spec B's in my Integra Type R (stock block, pistons, rods, header and tranny) and I hit consistent 12.9's at a little more than 104MPH in the 1/4 mile.
Hope the info helps....
Old Oct 7, 2001 | 12:37 PM
Tony the Tiger's Avatar
Default Re: Difference Between Toda Bs & C's? (Incognito)
Hey Incognito, you have some very impressive 1/4 ET and trap! How much power are you putting to the ground? 12.9 ET is a very impressive run, but I want to know your setup in detail. Is your motor truly stock with the exception of TODA spec B's? What slicks were you using, and what was your breakdown of your run?
Old Oct 8, 2001 | 10:07 AM
Type R's Avatar
stock header as well? i want to know your setup as well...nice times!
Old Oct 8, 2001 | 11:56 AM
One8Hatch's Avatar
New User
12.9 in an R? what am i doing wasting my time with my ls??? me third wants to know the set up..
Old Oct 8, 2001 | 02:06 PM
optiontoo's Avatar
New User
The C's won't work well with stock compression or engine management. The B's are way better for a stock B18C1 (you'll need the Type R inner and outer valve springs for the intake and exhaust.)
Old Oct 8, 2001 | 05:33 PM
slowcivic's Avatar
New User
Default Re: Difference Between Toda Bs & C's? (optiontoo)
Thanks everyone for your information!
Old Oct 9, 2001 | 09:06 AM
eternal21's Avatar
Default Correction
No, you need the Toda Valve springs for the B's. ITRs are NOT RECOMMENDED if you're revving past 8400 rpms
Old Oct 9, 2001 | 09:28 AM
optiontoo's Avatar
New User
Default Re: Correction (eternal21)
Um, I did say "stock" B18C1 didn't I?
hrs-parker
10
Jan 30, 2008 05:18 PM
allmotorgsr2000
Feb 16, 2004 03:04 PM
YellowR2000x2
Aug 21, 2002 01:02 PM
Black R
Dec 27, 2001 12:43 PM
