compression tester should be how many psi on ZC engine??
Old Jan 17, 2004 | 02:42 AM
91teg's Avatar
Default compression tester should be how many psi on ZC engine??
engine has 32-40k on it
same as topic. Thanks in advance
Old Jan 17, 2004 | 07:37 AM
blah13's Avatar
Default Re: compression tester should be how many psi on ZC engine?? (91teg)
The set number is around 180psi, however depending on the tester it can be off. Mine tested about 155 across all 4 and it still ran a 10.4 bone stock with my heavy 4dr in the 1/8th....strong motor. Just look for consistency.
Old Jan 17, 2004 | 08:06 AM
crxgator's Avatar
if you searched...or looked down the page, you would see someone else asked that question yestarday, it was already answered with info from the Helms manual...
ek_99_SiR
Mar 1, 2004 04:28 PM
91teg
Jan 16, 2004 12:06 PM
blah13
Jun 8, 2003 08:18 AM
turbozc2001
Apr 3, 2002 04:02 AM
