jdm cluster...s1 tranny...speed sensor
Old Jan 16, 2004 | 06:25 PM
R91Si's Avatar
Default jdm cluster...s1 tranny...speed sensor
what vss do i use for my cluster...i have an s1 tranny (cable vss) but the cluster needs an electric vss...so right now i have no speedo...any help is appreciated
Old Jan 16, 2004 | 07:03 PM
crxsirvtec's Avatar
Default Re: jdm cluster...s1 tranny...speed sensor (R91Si)
any vss from honda should work fine...
but if you need to buy a new one, use a 92-93 integra one...
you should find these anywhere..
i might beable to get you one.. if you need me too IM me and i will check a price for you..
Old Jan 16, 2004 | 08:12 PM
XJamesX's Avatar
Default Re: jdm cluster...s1 tranny...speed sensor (crxsirvtec)
Any Electronic Vss from 92 and up civic or 94 and up integra. the 92-93 tegs im pretty sure are cable driven.. Anyway I just installed an electronic Vss from a 92 civic in my crx for my 00- civic Si cluster and it worked perfectly.
This is the piece I got from a 92 civic Si. It is missing the gear and o rings in the pic. I got this piecs for $39 and then the o rings for $5 both from honda brand new.
This is the main part the actuall VSS. this is what produces the signal and sends it to the ecu and cluster. I got this piece from a 99 GSR for $35 used but it was missing the clip with the wiring so I just popped on some wires and sealed them up.
These 2 parts worked perfectly for me.
-James-
Modified by B18C5crx at 2:02 PM 1/17/2004
iheartjayDem
Aug 25, 2009 03:40 PM
spens 91 Ef
Feb 7, 2009 11:46 PM
zookr
13
Feb 14, 2006 06:53 PM
treepwood728
11
Oct 29, 2003 09:16 AM
