zc problems please help
Old Jan 16, 2004 | 05:53 PM
moochik84's Avatar
Default zc problems please help
I was cruising down the road at 55 when by car bogged and died all of the sudden
It turns smooth but will not start. We first thought it was out of time but checked and it is perfect. We've checked the fuel pump and it works. It is getting spark and gas at all four. It sounds just like it is out of time. Someone mentioned a cam position sensor. Would this cause my trouble? If anyone has any ideas please help me.
Old Jan 16, 2004 | 05:57 PM
joey1320's Avatar
Default Re: zc problems please help (moochik84)
the all mighty dizzy.
you gotta love those ZC motors...
happened to me twice. get a new one with a lifetime warranty.(auto zone, murray's)
good luck!
Old Jan 16, 2004 | 05:58 PM
moochik84's Avatar
Default Re: zc problems please help (joey1320)
sorry but what is a dizzy
Old Jan 16, 2004 | 06:00 PM
FAST AS's Avatar
distributor i know the fillin
Old Jan 16, 2004 | 06:02 PM
moochik84's Avatar
Default Re: zc problems please help (FAST AS)
The distributor is firing and seems to be firing in order.
Old Jan 16, 2004 | 06:23 PM
DJ_SaNdOz's Avatar
any codes?
Old Jan 16, 2004 | 06:26 PM
moochik84's Avatar
Default Re: zc problems please help (DJ_SaNdOz)
Im not getting any codes. I even swapped ecus but it still didn't throw any codes. We pulled the wires of the distributor and they fire.
Old Jan 16, 2004 | 06:59 PM
crxsirvtec's Avatar
3 things you need to start your motor..
Spark (which you say is good)
Gas/Air (Which you said was good)
Compression.....??
Also you can try taking out your plugs and see if they spark nicely..
Also this happen to me.. check the screw in the rotor inside your dizzy.. it will still spark if the rotor is free spining.. but not in order..
stella88
Jun 15, 2010 07:47 AM
91civicZcSw4p
Jul 22, 2008 01:44 PM
poopycar
Nov 2, 2004 11:26 AM
juanb
May 30, 2004 05:54 PM
civic2299
May 11, 2002 06:45 PM
