jumping rpm need heelllppppp!! gsr
Old Jan 16, 2004 | 02:56 PM
urgonnalearn2's Avatar
Default jumping rpm need heelllppppp!! gsr
I started my car today and i let it warm up a little then started driving. Now i stop at a light and tach is going up and down between 1500 -2000, car is stock with an intake. I need help to locate the problem, anybody?
Old Jan 16, 2004 | 04:37 PM
Kendall's Avatar
This problem has been covered at least 10 times within the last month, do a search and see what you can find.
Old Jan 17, 2004 | 11:28 AM
Default Re: jumping rpm need heelllppppp!! gsr (urgonnalearn2)
i did search
Old Jan 17, 2004 | 02:36 PM
david90's Avatar
it happeded to my accord too. It is your ignition coil. I changed mine and it is fixed.
Old Jan 17, 2004 | 06:11 PM
onePOINTsix's Avatar
Default Re: (david90)
it's probally not the coil, clean out your fast idle control valve on the bottem of the throttle body and it should go away, run a search for doing that for more info
Old Jan 17, 2004 | 06:53 PM
mmuller's Avatar
Mad Scientist
Default Re: (Sideout)
check if coolant is full and bleed it just in case.if that dont work, check the iacv, and if that dont work take the fitv(if your car is obd1) out and shake it; if it rattles take it apart and screw the little white piece back in
Old Jan 17, 2004 | 09:42 PM
salbaje's Avatar
your igniter might be crapping out. check that and iacv
xxi2icexx
Dec 9, 2008 07:48 AM
Depeche
Apr 12, 2007 02:36 AM
moonraker
Dec 26, 2005 09:19 AM
hondaivi211
Jun 1, 2005 05:25 PM
drisken
Sep 9, 2004 09:41 PM
