Stock CRX Spring rates?
Old Jan 16, 2004 | 12:07 PM
96-EJ6 B18C's Avatar
Default Stock CRX Spring rates?
Does anyone know what the stock spring rates are on the CRX Si? Thanks in advance.
Old Jan 16, 2004 | 11:58 PM
Tyson's Avatar
Default Re: Stock CRX Spring rates? (96-EJ6 B18C)
approximately 250f/150r, rear is progressive so its a range, but around 150.
Old Jan 17, 2004 | 10:01 AM
Default Re: Stock CRX Spring rates? (Tyson)
Thanks.
Old Jan 17, 2004 | 11:25 AM
Hybrid Invasion's Avatar
along the lines of the original question, what are some popular spring rates for coilovers for CRX's?
Old Jan 17, 2004 | 11:30 AM
SadisticRacing's Avatar
Default Re: Stock CRX Spring rates? (Hybrid Invasion)
Depends on what your looking for, just to lower for a daily driver I think there around 350 but I'm going to go 450f/900r because mine is for drag racing and only see's the street once in a great while
Old Jan 17, 2004 | 12:49 PM
Tyson's Avatar
What spring rates should I get?
http://www.norcalcrx.org/tyson/coilover.html#04
Old Jan 17, 2004 | 01:26 PM
I'm planning on running the H&R Race Springs with Tokicko blues and Suspension Techniques sways. The H&R's are rated at 470lb/in front and 360lb/in for the rears. They were the stiffest "spring" ie. not coilover setup that I was able to find. I think those rates will work well for autocross and street, any opnions?
Old Jan 19, 2004 | 05:11 AM
rapid_roy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C &raquo;</TD></TR><TR><TD CLASS="quote">I'm planning on running the H&R Race Springs with Tokicko blues and Suspension Techniques sways. The H&R's are rated at 470lb/in front and 360lb/in for the rears. They were the stiffest "spring" ie. not coilover setup that I was able to find. I think those rates will work well for autocross and street, any opnions? </TD></TR></TABLE>
470 is a little high for Tokico blues, you'll need revalved Koni's for that. Anything over 400 should use revalved Koni's.
Cheers,
Sean
Old Jan 19, 2004 | 09:12 AM
Default Re: Stock CRX Spring rates? (rapid_roy)
Thanks
Old Feb 2, 2004 | 08:17 AM
anybody know what the spring rate is for the Eibach ProKit?
Old Feb 2, 2004 | 10:14 AM
I'm not sure what the rate for the CR-X is, when I called Eibach they didn't have a listing for the rex spring rates. The Integra kit is 335LB front and progressive from 125-195LB for the rear. I'm ASSuming that the rates will be higher on the Integra kit than the CR-X kit.
Old May 11, 2004 | 05:17 PM
Renegade's Avatar
I always thought the front spring rates were higher in the front than the rear... I guess I was wrong
Is that to give more understeer from factory?
Renegade's Avatar
Default Re: Stock CRX Spring rates? (Renegade)
I am running 350F/ 400R GCs and it was tail happy.
Old May 11, 2004 | 05:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade &raquo;</TD></TR><TR><TD CLASS="quote">I always thought the front spring rates were higher in the front than the rear... I guess I was wrong
Is that to give more understeer from factory?</TD></TR></TABLE>
The weight distribution is toward the front of the car so the springs need to be stiffer to compensate for that.
Old May 18, 2004 | 07:38 PM
deviant1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade &raquo;</TD></TR><TR><TD CLASS="quote">I am running 350F/ 400R GCs and it was tail happy. </TD></TR></TABLE>
tail happy how? just wondering under what circumstances this would occur with stiffer rear springs.
Old May 18, 2004 | 07:48 PM
shaddr3's Avatar
Default Re: Stock CRX Spring rates? (deviant1)
im going to be selling my whole linkage soon.
dacrxguy
Oct 1, 2009 11:00 PM
gursh d
Suspension & Brakes
Oct 22, 2007 11:34 AM
94teg_RS
Oct 15, 2004 12:39 AM
rasta420
Jan 13, 2003 07:31 PM
