GSR Black Valve Cover...How Do you clean it?
Old Jan 16, 2004 | 11:07 AM
EnjoyTheRideDC2's Avatar
Default GSR Black Valve Cover...How Do you clean it?
Got my GSR....has 262,000 miles on it. The Valve cover is kind of dirty....I really just want it to look black again.....without stains or whatnot. ANy tips?
Old Jan 16, 2004 | 11:09 AM
Street Surgeon's Avatar
Default Re: GSR Black Valve Cover...How Do you clean it? (EnjoyTheRideDC2)
Use a soft bristled brush and some simple green.... Just be easy on it so as not to strip off any of the black finish.... It'll probably take some time, but it should do the trick.... If it gets SERIOUSLY nasty, then use some Castrol Superclean.... That stuff is NASTY, but it is hands down a SERIOUS de-greaser!!! Just make sure you wash it all off really good with some mild detergent soap when you're done.
Old Jan 16, 2004 | 11:13 AM
2quik4rwd's Avatar
Default Re: GSR Black Valve Cover...How Do you clean it? (Street Surgeon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Street Surgeon &raquo;</TD></TR><TR><TD CLASS="quote"> If it gets SERIOUSLY nasty, then use some Castrol Superclean.... That stuff is NASTY, but it is hands down a SERIOUS de-greaser!!! .</TD></TR></TABLE>
be careful with this product it says on the label not for aluminum or painted surface which is exactly what you are cleaning. I like to clean and repaint myself. but not everybody wants to take the time to do this. Simple grren is good stuff!!
Old Jan 16, 2004 | 11:16 AM
96AllMotorDC2's Avatar
when i want a good cleaning, brake cleaner does the trick for me. dont use it to much though. it starts eating away at the coating.
Old Jan 16, 2004 | 11:17 AM
BolivianDc2's Avatar
Default Re: GSR Black Valve Cover...How Do you clean it? (2quik4rwd)
be careful i cleaned mine w/ simple green and it came out like this
JUST KIDDING
the method he described should work, works on ITR valve covers
Old Jan 16, 2004 | 11:24 AM
wooderson's Avatar
Default Re: GSR Black Valve Cover...How Do you clean it? (Bolivianstrtwpn)
when I did mine I just cleaned the surface as best I could with power clean and spray painted the valve cover black. then i took some sand paper and went over the DOHC VTEC to make it shiny again.
Old Jan 16, 2004 | 11:31 AM
:jdmshmaydm:'s Avatar
After you clean it put armor all on it. That's what I do when I clean it. Once every 6 months or something. Makes it bling very black.
Old Jan 16, 2004 | 11:39 AM
shuned 1's Avatar
simple green and a presure washer make it sooooooo pretty
Old Jan 16, 2004 | 03:49 PM
.Beaver's Avatar
Bloody Beaver
Default Re: GSR Black Valve Cover...How Do you clean it? (poopie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poopie &raquo;</TD></TR><TR><TD CLASS="quote">simple green and a presure washer make it sooooooo pretty </TD></TR></TABLE>
jryKC
Nov 16, 2016 08:28 PM
prettylew
Nov 21, 2007 02:20 PM
ironchef25
May 8, 2005 07:06 PM
GUNNER666
Sep 5, 2004 10:42 AM
eknine
Aug 2, 2003 06:17 AM
