:FAQ: How to Remove CRX / Civic Steering Wheel
Old Jan 16, 2004 | 02:26 AM
crxforum's Avatar
Default :FAQ: How to Remove CRX / Civic Steering Wheel
Yes my interior is white and I hate it. Anyways here is the FAQ.
Step #1:
Start by removing the 'H' in the center of the steering wheel. You can use a small screwdriver to get behind it and pry it out. Just a note; if you press to hard trying to get the screwdriver behind there you will blow your horn, and your neighbors don't like that at 1am.
Step #2:
Look down the hole behind the 'H'. You will see a bolt down there. It is 19mm.
Step #3:
Next take a ratchet, with a 19mm socket on the end, and place it down the hole. It helps to turn the bolt if you lock the steering wheel. Then get out of the car and grab the wheel with one hand and the ratchet with another. Then put as much pressure on the ratchet because the bolt is a bitch.
Step #4:
All that is left is to remove the wheel. Just tug a bit and it should come right off with no problem at all.
CRX Forum
Old Jan 16, 2004 | 02:31 AM
^jefs0ng's Avatar
Banned
Wow that's a quickie writeup. Too bad I can't use it, as I already have a momo wheelz0r on there. nice picts though
Old Jan 16, 2004 | 06:47 AM
Driven's Avatar
Default Re: (.jefs0ng)
Tip: use air tools, bolt comes right out.
also, you forgot the alignment of the steering wheel when you reinstall it (which can be a bitch.
Old Jan 16, 2004 | 06:50 AM
d357r0y's Avatar
Default Re: (Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">
also, you forgot the alignment of the steering wheel when you reinstall it (which can be a bitch.</TD></TR></TABLE>
True.. make sure your wheel is straight up and down and use a marker to mark the nut/bolt before you remove them.
Old Feb 16, 2007 | 11:36 AM
stemiched's Avatar
Default Re: :FAQ: How to Remove CRX / Civic Steering Wheel (crxforum)
i just got an after market steering wheel, and don't have any power tools... i can get the bolt to loosen... any suggestions?
Old Feb 16, 2007 | 11:38 AM
MagnaniEG6's Avatar
Default Re: :FAQ: How to Remove CRX / Civic Steering Wheel (stemiched)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stemiched &raquo;</TD></TR><TR><TD CLASS="quote">i just got an after market steering wheel, and don't have any power tools... i can get the bolt to loosen... any suggestions?</TD></TR></TABLE>
Muscle power
Old Feb 16, 2007 | 11:44 AM
stemiched's Avatar
Default Re: :FAQ: How to Remove CRX / Civic Steering Wheel (MagnaniEG6)
i gots none... and it doesn't help that my steering wheel doesn't seem to lock up either...
Old Feb 16, 2007 | 11:46 AM
MagnaniEG6's Avatar
you never took out the key and wiggle the steering wheel. Get someone else to hold the steering
Old Feb 16, 2007 | 11:50 AM
stemiched's Avatar
yea thats what i tried... i can turn the steering wheel the whole way with the key out... this may or may not having something to do with my steering rack being loose... gatta replace that when i get some $...
MagnaniEG6's Avatar
Probably cause of that
Old Feb 16, 2007 | 11:50 PM
GSR CRX's Avatar
just turn the steering wheel to all the way to the left as far as it would go. then use the ratchet and loosen that 19mm nut. getting the wheel off may be a bitch if you dont have the right tools. i learned that the hard way.
Old Feb 17, 2007 | 08:46 AM
wiZCo's Avatar
Stouts 'n' Scotch
I never had a problem getting that nut off with hand tools...... try having somebody hold it for you.
Old Feb 17, 2007 | 09:51 AM
1991hb's Avatar
the first time I took my stock wheel off it was a bi*ch but I finally got it...it just takes a little muscle power
Old Feb 17, 2007 | 12:59 PM
harmonator84's Avatar
Default Re: (1991hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991hb &raquo;</TD></TR><TR><TD CLASS="quote">the first time I took my stock wheel off it was a bi*ch but I finally got it...it just takes a little muscle power</TD></TR></TABLE>
X2
Old Feb 17, 2007 | 03:05 PM
bagpipe goatee's Avatar
after turning the wheel all the way to the left (or locking it) put your wrench on. get a pipe that fits over the rachet, and use it to give you more leverage. We call these "Cheater bars" or "Cheeter bars"
Old Feb 17, 2007 | 03:27 PM
stemiched's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">after turning the wheel all the way to the left (or locking it) put your wrench on. get a pipe that fits over the rachet, and use it to give you more leverage. We call these "Cheater bars" or "Cheeter bars"</TD></TR></TABLE>
yea i know of that trick, but i could not find a bar laying around... but i dont know why but for once my steering wheel finally locked up and i got it, so thanks guys, its off and the new one is on
Old Feb 17, 2007 | 03:32 PM
Hamstr323's Avatar
Default Re: (stemiched)
OR you can use an + tire iron
Old Feb 23, 2007 | 05:42 PM
benihana881's Avatar
wow thanks
Old Feb 23, 2007 | 06:29 PM
89efDUSTY's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">I never had a problem getting that nut off with hand tools...... try having somebody hold it for you.</TD></TR></TABLE> same here hand tools
funny because this thread is like comon knowledge and yet this question arises like twice a month...and this wont be the end because the search button is invisible for some
Old Feb 23, 2007 | 06:34 PM
stemiched's Avatar
Default Re: (89efDUSTY)
the search button is not even needed to find this... it is in the faqs page...
for the record i asked my question about this on this thread instead of making a new one
Old Feb 23, 2007 | 06:42 PM
grog's Avatar
Default Re: (harmonator84)
wow I did an insane job of removing mine. i didnt know the h came out 3 times i spent hours trying to get to the screws mounted behind the horn panel out to get to the bolt holding the wheel on . oh my what a waste of time
now i know!
and I'll probly never remove it again
Old Feb 23, 2007 | 06:43 PM
stemiched's Avatar
Default Re: (grog)
lol, even if i never read or did this i would have tried to take the H off first... but that may be because i knew the H came off because i stole a couple from junk yards...
Old Feb 23, 2007 | 06:48 PM
grog's Avatar
Default Re: (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">Yes my interior is white and I hate it. CRX Forum</TD></TR></TABLE>
hey i think i saw a thread where people had used laquer thiner or something to remove paint safely(on plastics)
do a search in all the forums, im not sure where i saw it
ya pretty folish, once you do it once it all becomes clear
Old May 8, 2007 | 03:35 PM
blakaraknyd's Avatar
sheez man.. you coulda told me this before... now my horn cover (everything around the h) is missing... =P sorry... i'm impacient
Old May 8, 2007 | 03:37 PM
EL Vap133's Avatar
I just use this:
