problems
i just swaped a d16z6 into my 89 si hatch. i am having a few proplems with it
1. i can rev it to 3 with no problems but if i try to take it to 4 it bogs for a second or two and then allows it to rev.
2. i havent got the right ecu yet so vtec is on a switch right now i can turn vtec on at 5 and it pulls like it is supposed to but as soon as it hits 6 i bogs.
3. after i take it for a ride i come back there a strong gas smell and i cant see any leaks what could that be.
let me know what you guys think about these problems and if you need anymore info about other things on the care just ask i will be glad to help thanks
#1 get the correct ECU!
As for the fuel leak(s) check the return line coming off the the fuel pressure regulator and check the banjo fittings that connect to the fuel filter and the fuel rail. Hope that helps
Dan-Dillinger
Apr 21, 2006 11:26 AM
