Sunroof on an HF?
If the VIN starts JHMED8 your car did NOT come with a factory sunroof. Period. End of disscusion. ONLY the Si's have a FACTORY POWER sunroof!
However someone could've put one in after the fact.
just curious, are you sure that you have an hf? just wondering because it could be the dx which does come with a factory sunroof. everything else is pretty much the same as the hf except for that and the engine.
<--- Also has an '89 Hf with a sunroof.
They're most definitely aftermarket.
Also, Hf's will have a 2 spoke steering wheel making them easy to ID from the Si's and Dx's 3 spoke wheel.
I asked this question on Hondahookup.com way back when I first got the car because I was doing the same wtfing, and that is the answer I got. No matter how stock the sunroof itself looks it's pretty easy to tell it's aftermarket when you check the wiring.
Modified by Hybridize at 4:59 PM 1/16/2004
Yep, its an Hf. My vin stats with JHMED8. Its not a sliding sunroof like the SI's but rather a pop up sunroof with hinges. I guess it is an aftermarket one. However I just bought a replacement sunroof off of ebay. The seller claims it will fit any crx. Makes me wonder if it will fit now. I doubt all aftermarket sunroofs are the same for the CRX. I'll wait and see if it will fit.
http://cgi.ebay.com/ebaymotors...28478
Do you have a pic of your suroof? I want to see if it is similar to mine. Also I may be interesed in purchasing your old sunroof from you if the one I bought dosen't fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98GeeYes-Are »</TD></TR><TR><TD CLASS="quote">Do you have a pic of your suroof? I want to see if it is similar to mine. Also I may be interesed in purchasing your old sunroof from you if the one I bought dosen't fit. </TD></TR></TABLE>
i can get one up later, where in nor cal are you?
I put in an aftermarket sunroof in my hf. its an electric spoiler type and i got it from http://www.webasto.us/home/en/homepage.html
very nice sunroof.
very nice sunroof.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxxrc »</TD></TR><TR><TD CLASS="quote">I put in an aftermarket sunroof in my hf. its an electric spoiler type and i got it from http://www.webasto.us/home/en/homepage.html
very nice sunroof.
thanks for the link!!!
very nice sunroof.
</TD></TR></TABLE>thanks for the link!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowman »</TD></TR><TR><TD CLASS="quote">um no, DX and HF and std all have 2 spoke.
si got 3 spoke steering wheel.</TD></TR></TABLE>
Thanks for clearing that up, I guess I recieved some bad info or just didn't recall it right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98GeeYes-Are »</TD></TR><TR><TD CLASS="quote">Yep, its an Hf. My vin stats with JHMED8. Its not a sliding sunroof like the SI's but rather a pop up sunroof with hinges. I guess it is an aftermarket one. However I just bought a replacement sunroof off of ebay. The seller claims it will fit any crx. Makes me wonder if it will fit now. I doubt all aftermarket sunroofs are the same for the CRX. I'll wait and see if it will fit.
http://cgi.ebay.com/ebaymotors...28478</TD></TR></TABLE>
That sunroof is a fraud. Original my ***. You should retract your bid due to false advertising.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">
i can get one up later, where in nor cal are you?</TD></TR></TABLE>
I'm in the North bay
