Honda S2000 Honda S2000
Need a new clutch, what should I get?
Old Jan 15, 2004 | 03:29 PM
KooK's Avatar
Mustang Sally
Default Need a new clutch, what should I get?
2002 Honda S2000, this thing wont have a whole lot of mods, maybe intake, exhaust and a few other bolt ons so I don't need anything heavy duty. I'd also like to keep the pedal stiffness the same.
Go figure though, 24k miles and slipping.
Old Jan 15, 2004 | 06:32 PM
munky99999's Avatar
Default Re: Need a new clutch, what should I get? (KooK)
automatic
Old Jan 15, 2004 | 07:16 PM
munckee's Avatar
geez. 24k and slipping already? Do you do a bunch of clutch dumps or what?
I think the general recommendation is an aftermarket preasure plate with a stock clutch plate.
Old Jan 15, 2004 | 07:56 PM
KooK's Avatar
Mustang Sally
Default Re: Need a new clutch, what should I get? (munky99999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by munky99999 &raquo;</TD></TR><TR><TD CLASS="quote">automatic</TD></TR></TABLE>
Go burn in hell, I SHALL NEVER DRIVE AN AUTO for they are slow and easy like your mom
But stock clutch with an aftermarket pressure plate, I guess I should get a new OEM throwout bearing also.
What pressure plate should I get?
Oh, and I have no clue why its slipping already but I'm thinking its a faulty pressure plate simply because this exact same thing happened to my stang.
Old Jan 16, 2004 | 11:44 AM
evil vapor's Avatar
most aftermarket pressure plates for this car are simply modified stock pressure plates. Most will have 30% more clamping force. You wont notice a stiffer pedal with the 30% stiffer pressure plate and it's your best bet as the clutch wont slip as bad as stock. Just buy another stock friction disc and like you said, a new throwout bearing. While your in there, you may see it fit to upgrade the flywheel but I will say the differences are small from the stock flywheel to an aftermarket.
Old Jan 16, 2004 | 02:46 PM
Project SSAP1's Avatar
Default Re: Need a new clutch, what should I get? (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">most aftermarket pressure plates for this car are simply modified stock pressure plates. Most will have 30% more clamping force. You wont notice a stiffer pedal with the 30% stiffer pressure plate and it's your best bet as the clutch wont slip as bad as stock. Just buy another stock friction disc and like you said, a new throwout bearing. While your in there, you may see it fit to upgrade the flywheel but I will say the differences are small from the stock flywheel to an aftermarket. </TD></TR></TABLE>
what are some good pressure plates?? and ive been noticing that after drving the car the pedal is getting a lil stiffer..is this the throwout bearing??
Old Jan 16, 2004 | 02:52 PM
evil vapor's Avatar
Default Re: Need a new clutch, what should I get? (Project SSAP1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project SSAP1 &raquo;</TD></TR><TR><TD CLASS="quote">
what are some good pressure plates?? and ive been noticing that after drving the car the pedal is getting a lil stiffer..is this the throwout bearing??</TD></TR></TABLE>
not saying what I'm running is what to get but I've had no problems with it. Again, most aftermarket pressure plates are modified stock units, so one could be bold enough to say the spoon, mugen, etc are basically the same but I would get burned at the stake if I said that was fact.
Some signs of a failing throwout bearing may be a sticky clutch or excessive noise but the latter is hard to diagnose as the stock tranny is noisy.
Old Jan 17, 2004 | 11:48 AM
KooK's Avatar
Mustang Sally
Awesome information and all but can you please name off a few brand names that would be ok to get. I don't want to pick out any pressure plate only to find out its worse.
Thanks man!
Old Jan 17, 2004 | 01:11 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KooK &raquo;</TD></TR><TR><TD CLASS="quote">Awesome information and all but can you please name off a few brand names that would be ok to get. I don't want to pick out any pressure plate only to find out its worse.
Thanks man! </TD></TR></TABLE>
just to name a few again, spoon, mugen, act, the list goes on and on. It's up to you to choose one.
Old Jan 17, 2004 | 05:21 PM
theSQad's Avatar
cusco &lt; -- $$ ACT makes a good pressure plate ... spoon &lt;-- the best !
Old Jan 21, 2004 | 03:24 PM
LaterApex's Avatar
Default Re: Need a new clutch, what should I get? (thesqad127)
I have the Mugen PP with a SPEC Star Stage II kevlar clutch and it's just great. Some pretty good driver's have taken my car out onto the track and the first question they ask when they get out of the car is what my clutch set up is because they like it so much.
You need to send your PP to SPEC to have it properly mated to the Star clutch but it's worth it.
Old Jan 21, 2004 | 05:18 PM
soundzero's Avatar
So im assuming you are not considering stock clutch?
Old Jan 21, 2004 | 07:25 PM
Razor's Avatar
Default Re: Need a new clutch, what should I get? (soundzero)
the stock clutch isnt weak, its the presure plate. get a stronger pressure plate and youll be fine.
Old Jan 25, 2004 | 08:31 PM
MustangGT's Avatar
Get a SPEC clutch! They grip like nothing else! You can get a Stage 1 for around 179-199 for the full kit.
Old Mar 20, 2004 | 09:02 AM
teknoracing's Avatar
Default Re: (MustangGT)
Where can i get a SPEC clutch at?? Thats a really good deal. Websites or any shops in southern cali would help
Old Mar 20, 2004 | 10:02 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MustangGT &raquo;</TD></TR><TR><TD CLASS="quote">Get a SPEC clutch! They grip like nothing else! You can get a Stage 1 for around 179-199 for the full kit.</TD></TR></TABLE> ?
Old Mar 23, 2004 | 10:14 PM
unstopabledj's Avatar
Default Re: (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote"> ?</TD></TR></TABLE>
yeah my friend is also going to order a clutch from that company for his 91 turbo mr2 but i never heard or had anyone experience with that brand, reason he is going to order from them is because he said " its way cheaper and will last longer than an ACT Clutch kit" anyone with suggestions whether its good or bad?
Old Mar 25, 2004 | 06:03 PM
civicVX's Avatar
i have a brand new stock disk for sale let me know if your interested? stock disk with a mugan pressure plate is nice set up or like others are saying any other good pp. let me know if you interested
Old Mar 26, 2004 | 09:32 AM
yod88's Avatar
get a stock clutch, i dunno about what to get for a pressure plate though, but 24k miles and your are slipping already? i have seen original clutchs still in the car close to 50k miles...24k seems kinda early...
Old Mar 26, 2004 | 08:00 PM
White_S's Avatar
Get a Spoon or Exedy organic clutch kit
they are 30% over stock but ride like stock
Old Mar 26, 2004 | 08:56 PM
spirit R
Guest
Posts: n/a
Default Re: Need a new clutch, what should I get? (White_S)
Spoon is way overpriced rebadged OEM other company brand
ACT builds the best pressure plates for street use. That and a stock clutch disk is all you need.
It will handle the acceleration unless you try to drag race the car which Honda never built it for and any cheap *** mustang is ultimately better for. The end result being a P.O.S.
Old Mar 29, 2004 | 01:54 PM
riceisnicenv's Avatar
Default Re: Need a new clutch, what should I get? (Duke Togo)
my mom's old nissan maxima had 190k miles and still had the stock clutch.... she doesn't drive hard at all though
Old Apr 10, 2004 | 04:55 AM
civicVX's Avatar
Default Re: Need a new clutch, what should I get? (civicVX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicVX &raquo;</TD></TR><TR><TD CLASS="quote">i have a brand new stock disk for sale let me know if your interested? stock disk with a mugan pressure plate is nice set up or like others are saying any other good pp. let me know if you interested</TD></TR></TABLE>
still have the disk for sale
Old Apr 10, 2004 | 06:39 PM
ACTman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duke Togo &raquo;</TD></TR><TR><TD CLASS="quote">ACT builds the best pressure plates for street use. That and a stock clutch disk is all you need. </TD></TR></TABLE>Thanks for the props. There are many wannabees out there. The stock disc is pretty good on the S2000 and we still sell them but we also started making a performance organic style which is a little more aggressive but still streetable and not too expensive.
We use a stronger diaphragm than stock rather than just changing the geometry or using harsh friction materials (for street). Our parts are all new, tested, balanced, and SFI certified for racing.
Choose wisely.
eg customs
Nov 7, 2008 09:28 AM
blue_hatch
Sep 1, 2008 06:30 PM
itr1235
Apr 11, 2007 11:17 PM
bboylito
Apr 10, 2005 05:47 PM
yaya
Mar 14, 2004 11:20 AM
