Rpm 70mm billet throttlebody
Old Jan 15, 2004 | 01:08 PM
TURBOFTW's Avatar
Default Rpm 70mm billet throttlebody
sold
Modified by h22dude at 3:10 PM 1/19/2004
Old Jan 15, 2004 | 02:15 PM
Adriano's Avatar
Default Re: Rpm 70mm billet throttlebody (h22dude)
for what car is it? Will it fit a 94 gsr? Very interestes. Thanks
Old Jan 16, 2004 | 12:24 AM
blownR's Avatar
please email me at yellow_itr@hotmail.com very interested
Thanks
Chad
Old Jan 16, 2004 | 05:11 AM
Paluce's Avatar
Default Re: Rpm 70mm billet throttlebody (blownR)
what size is the manifold side? Very interested.
Old Jan 16, 2004 | 05:14 AM
b18crx's Avatar
post vouches and which manifold
Old Jan 16, 2004 | 06:58 AM
TURBOFTW's Avatar
Default Re: Rpm 70mm billet throttlebody (b18crx)
pm's sent....ttt
Old Jan 16, 2004 | 02:06 PM
TURBOFTW's Avatar
ttt
Old Jan 16, 2004 | 05:29 PM
mwvnos's Avatar
very interested...what motor is it for?? email markvh22@yahoo.com....
Old Jan 16, 2004 | 05:37 PM
HYBRID_H@TCH's Avatar
Default Re: (5genh22psi)
Iam a dealer for these so I will help this seller out..
this TB will fit any civic,integra,prelude manifold..from his post it is a 70mm TB which means its a 70/68mm 70mm starting at the front and tappers to a 68mm at the plate. if your trying to put it on a 90-91 integra you can take the map sensor off and it has treads for a fitting to run a vac line to the remote map (or on any 92-00 car) for a 3 bar map sensor..hope this helps you guys and good luck with the sale.
Old Jan 16, 2004 | 08:55 PM
h22 civic's Avatar
Default Re: (99Hybrid_Hatch)
prelude map is mounted on the firewall gsr is on the throttle body
Old Jan 16, 2004 | 11:55 PM
SweetChin's Avatar
Default Re: (h22 civic)
im totally interested... does it come with the sensors???
Old Jan 17, 2004 | 02:19 AM
I have a 97 lude and the map is on the TB..but anyways..you can screw a fitting in to the spot where the TB mounted map is and run the line to the map.
Old Jan 17, 2004 | 08:50 AM
0evilEMPIRE0's Avatar
sent im
Old Jan 17, 2004 | 09:40 AM
TURBOFTW's Avatar
Thanks 99 hybrid hatch.....it comes with the sensors....
Old Jan 17, 2004 | 04:51 PM
TURBOFTW's Avatar
Default Re: (h22dude)
ttt
Old Jan 17, 2004 | 04:58 PM
sent im
Old Jan 17, 2004 | 05:21 PM
Default Re: (0evilEMPIRE0)
THANKS FOR THE T-BODY!!!
PabloM
Nov 5, 2013 03:36 AM
Topdawgg
Jun 25, 2007 10:02 AM
94integragsr
Apr 26, 2007 06:10 PM
shabasoft
Aug 26, 2004 06:39 AM
The Mole
Nov 23, 2002 10:22 AM
