DC integ rear sway instal on EG coupe what do i need to do?
already searched and from what i did see in the search a DC integ rear sway bar can be mounted on a EG with some mods, does anyone know what they are? i just got a EG coupe and i have a DC sway bar can anyone help me out??
rear lca with mounting points. reinforcement kit. 4 bolts,nuts, and washer. a drill to make the holes bigger on the subframe. you do have all the parts on the bar right? endlinks, bushing , bracket.
I don't know about all the drilling of the subframe. Mine was threaded and the DC hardware bolted in once I cleaned the threads out, even though they weren't that bad. Should be a bolt in affair.
I did however get an alignment afterwards to correct some toe issues after swapping lca's.
ya i have all that stuff minus the rear LCA im going to put the car on jacks and see if i can figure it out with out buying the rear LCA's l post pics once im done but for now im going to see if i can make something happend
