Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Accord Eyelet Bolts
Old Jan 15, 2004 | 11:48 AM
DIYaccord's Avatar
Default Accord Eyelet Bolts
does anyone know where i can get these for my accord's bolt pattern? i'm installing a 4pt harness and need these.
if not where to get them, does anyone know the size of the thread (pitch size i think is what it's called)
Old Jan 15, 2004 | 12:14 PM
MightyMouseTech's Avatar
Default Re: Accord Eyelet Bolts (DIYaccord)
Get them anyplace that sells harnesses.
All cars use the same thread on the seat belt bolts. (at least Nader did one thing right)
Old Jan 15, 2004 | 12:20 PM
travis's Avatar
Default Re: Accord Eyelet Bolts (MightyMouseTech)
click --> http://www.racerwholesale.com/...dware
Old Jan 15, 2004 | 04:19 PM
Knestis's Avatar
Default Re: Accord Eyelet Bolts (travis)
The eyebolts that came with my Willans were 7/16 NF threads - not metric. I have spares if anyone needs them.
Kirk
Old Jan 15, 2004 | 08:55 PM
DIYaccord's Avatar
Default Re: Accord Eyelet Bolts (Knestis)
ME ME ME!!!!
oh, btw, how do you bolt them down? big socket? or pliers?
Old Jan 15, 2004 | 09:25 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord &raquo;</TD></TR><TR><TD CLASS="quote">ME ME ME!!!!
oh, btw, how do you bolt them down? big socket? or pliers?</TD></TR></TABLE>
Do you mean to hold the eye bolt? I just stuck a 3/8 socket extension through the eye and turned it until it hit something to hold it in place.
Old Jan 16, 2004 | 07:29 AM
Knestis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord &raquo;</TD></TR><TR><TD CLASS="quote">ME ME ME!!!! ...?</TD></TR></TABLE>
Does that mean you want the eyebolts? I want to be clear that they will NOT thread into your OE holes - at least I think they won't.
K
Old Jan 16, 2004 | 07:55 AM
kedwards's Avatar
I got my eye-bolts from Pegasus, I believe, but they fit my OE threaded holes. They were from England, as I recall.
I used them to hold my OE shoulder harness in, but allowed me to clip my 4-point system in.
Old Jan 16, 2004 | 08:05 AM
DIYaccord's Avatar
oh, nevermind then...
could i get these bolts at home depot?
Old Jan 16, 2004 | 08:39 AM
bad-monkey's Avatar
the bolts i got with my sparco harnesses were 7/16 - 20 and they threaded into my OE locations on the prelude.
home depot has 7/16 - 20 bolts but not eye bolts...
Old Jan 16, 2004 | 11:55 AM
Knestis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord &raquo;</TD></TR><TR><TD CLASS="quote">...could i get these bolts at home depot?</TD></TR></TABLE>
NO. These are forged pieces that are way tougher than home store junk. Do this - get a 7/16 NF bolt and see if it threads into your hole. It should be easy. If it does, email me at kirk.knestis@evaluand.com and I'll send a pair to you for the cost of shipping.
K
Old Jan 16, 2004 | 12:38 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knestis &raquo;</TD></TR><TR><TD CLASS="quote">
K</TD></TR></TABLE>
i did not notice that they were forged, but now that i examine closer, they are. good call dr.k...
Old Jan 16, 2004 | 10:28 PM
DIYaccord's Avatar
ok, i'll do that and we'll go from there
Old Jan 18, 2004 | 07:02 PM
DIYaccord's Avatar
7/16th inch is confermed NOT to fit, i repeat, does NOT fit
ok, so what is the pitch then?
Old Jan 18, 2004 | 07:06 PM
Tyson's Avatar
Default Re: (DIYaccord)
the standard 7/16 pitch FORGED eyebolt is not supposed to fit in the stock seat bolt anchors. youre supposed to drill your own holes in the chassis.
Old Jan 18, 2004 | 07:13 PM
Knestis's Avatar
I have had correct eyebolts provided by harness manufacturers fit in the OE holes on Mazdas and VWs but don't remember now if that was because (a) the bolts were metric, or (b) the holes were SAE (for whatever wacky reason).
Take the OE bolts out of your car to the hardware shop and keep trying nuts until you get a fit...
K
Old Jan 21, 2004 | 12:19 PM
DIYaccord's Avatar
ok, sounds good...
Old Jan 21, 2004 | 03:57 PM
bad-monkey's Avatar
wow, that's weird. it fit perfectly in my car...
Old Jan 21, 2004 | 07:16 PM
DIYaccord's Avatar
Default Re: (bad-monkey)
i heard someone say 7/16" x 20 does the 20 mean the length of the bolt or the length inbetween the threads? if the 2nd one is true, then i might have just bought the wrong bolt
Old Jan 21, 2004 | 07:18 PM
Knestis's Avatar
"20" is the pitch of the thread - the number of threads per inch. That thread is sometimes called 7/16 NF - or "national fine" I believe.
K
Old Jan 21, 2004 | 07:39 PM
DIYaccord's Avatar
Default Re: (Knestis)
you still have those eyebolts? if so, how many?
i'm gonna go buy the CORRECT bolt tomarrow (rolleyes)
Old Jan 22, 2004 | 04:06 AM
Knestis's Avatar
I have four of those eyebolts and will send you two** for the cost of packing and shipping BUT I want to make sure that they work for you first. Let me know what you learn from your next test.
K
** I'm funny like this but the other two would be dependent on an explanation of how you are planning on using them. I used to sell safety equipment and my conscience won't let me participate in something like bolting shoulder belts to the floor behind a seat with no rollcage.
Old Jan 22, 2004 | 06:19 AM
DIYaccord's Avatar
the way i'm bolting it is the sholder straps will cross X on the back then attach to the rear driverside passenger seat belt mounting points and the lap belt will go to the stock locations.
i've checked it out, that's the safest... so can i get all 4 then? if my test works
Old Jan 22, 2004 | 07:20 AM
travis's Avatar
i've checked it out, that's the safest... </TD></TR></TABLE>
You checked it out, and the safest way to mount a harness is to cross the shoulder straps to the floor in the rear?
Old Jan 22, 2004 | 11:44 AM
DIYaccord's Avatar
Default Re: (travis)
oops, sorry
not to the floor, but to the rear seat belt mouting points
(not a honda, it's a ford mustang, but you get the point)
i want to take out those two stock bolts and replace them with the eyelet bolts so the entire system is removable
and about crossing them, i'd have my right sholder belt connected to the bolt closest to the door, and my left sholder belt connected to the other bolt (near the center of the seat).
and the lap belt would go to the stock locations (on driver's seat, and the other on the pillar on the floor)
