No Heat!!
Have a friend look in the engine compartment and by the firewall there will be a coolant line running to the heater core.. it's on the passanger side of the car... on this hose is a little valve that has a small calbe attached to it.. Make sure that the cable is attached number one, and then see if when the **** is turned that the valve is moving... at least taht way you can figure out of the problem with the cable is inside or outside the car.
WOOHOO! I have heat now
Turns out the cable that goes to the Heater Control Valve (lets the water run through the heater core) came off, so even though i switched it to heat, no water was running through the heater core, thus no heat. doh!
targa2
14
Jun 29, 2004 10:40 AM
