Type R or LS Turbo in a CIVIC
Old Jan 15, 2004 | 07:14 AM
Bictorious's Avatar
Default Type R or LS Turbo in a CIVIC
Ok im planning to have my 95 civic coupe for a long time so what should i go for that would burn lower b series for quite a while? Right now i have an LS and planning to boost it but i dont think i want to keep it for long cause i might blow something. I've heard alot of things about Type R and im impressed. I dunno, what do you guys think?
Old Jan 15, 2004 | 07:15 AM
E-Rok's Avatar
EPIC TUNING
Default Re: Type R or LS Turbo in a CIVIC (Bictorious)
turbo LS for SURE.
Old Jan 15, 2004 | 07:22 AM
ki3t's Avatar
This user can set his title.
Type-r hands down. Nothing better the a stock motor that has lots of potential and nothing better than some good power that has not been tampered with.
Type-r has lots of reliability if you care about that also.
I feel that once you tamper with an engine it will never be safe again IMO and won't feel as reliable.
Modified by kIeT-y0 at 12:33 PM 1/15/2004
Old Jan 15, 2004 | 07:29 AM
94blackhatch's Avatar
Default Re: Type R or LS Turbo in a CIVIC (kIeT-y0)
build the ls then turbo the **** outta it u can put nasty power down
Old Jan 15, 2004 | 07:30 AM
RTE117's Avatar
it comes down to reliability.. Boosted LS will hand the R motor it's *** in your exact chassy and be cheaper, but if you're that worried about reliability go with an N/A motor.
Pete_SI's Avatar
It depends on what you want.
For reliability for sure its the Type R
For power It the LS turbo
Old Jan 15, 2004 | 07:35 AM
b18bEG's Avatar
ls/turbo fo shizzle my nizzle
E-Rok's Avatar
EPIC TUNING
Default Re: Type R or LS Turbo in a CIVIC (Pete_SI)
heh. a turbo LS @10psi PROPERLY TUNED will be just as reliable as a type-r. also if you happen to blow it, throw a new shortblock in for DIRT cheap
Old Jan 15, 2004 | 07:53 AM
97Civic-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kIeT-y0 &raquo;</TD></TR><TR><TD CLASS="quote">Type-r hands down. Nothing better the a stock motor that has lots of potential and nothing better than some good power that has not been tampered with.
Type-r has lots of reliability is you care about that also.
i agree
Old Jan 15, 2004 | 07:59 AM
Bictorious's Avatar
which one is cheaper to do?
Old Jan 15, 2004 | 08:04 AM
Bictorious's Avatar
Also, would i get alot more power if i had a VTEC controller?
Old Jan 15, 2004 | 08:10 AM
RTE117's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bictorious &raquo;</TD></TR><TR><TD CLASS="quote">Also, would i get alot more power if i had a VTEC controller?</TD></TR></TABLE>
VAFC's are good for tuning purposes, but unless you've got extensive modifications you won't see much but mainly midrange gains.
Atlas's Avatar
Default Re: Type R or LS Turbo in a CIVIC (IDriveAHonda)
Boost is fun. Thats all you need to know.
Old Jan 15, 2004 | 08:11 AM
egtype-r's Avatar
la/vtec for sure then boost it you'll rape the type-r, just make sure you build it right, then you'll be good to go
Old Jan 15, 2004 | 08:17 AM
mattssi's Avatar
If you want a hassle free good time car, then get a type r, if you want something to play with, and have time to tune, and most of all, patience, go turbo! And a ls motor is a good place to start!
Old Jan 15, 2004 | 08:24 AM
swatdog's Avatar
If you can't answer these questions yourself, then i recommend u stay an an NA car. Learn your facts/info before you jump into the world of boost. Its not a world for amateurs.
Old Jan 15, 2004 | 08:32 AM
revhigh96's Avatar
Do what I did, turbo a C5. Actually to answer your post I have been driving my turbo'd car for 8 months now and I have not had any problems. I would say LS turbo or any other B series with a turbo but LS would probably be your cheapest bet. Just remeber to get a wastegate with a low boost spring in it. Then just leave your boost controller home and you wont have any problems. Thats what I do so I dont turn it up on a daily basis.
Old Jan 15, 2004 | 09:19 AM
opi's Avatar
opi
Default Re: (revhigh96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhigh96 &raquo;</TD></TR><TR><TD CLASS="quote">Do what I did, turbo a C5. Actually to answer your post I have been driving my turbo'd car for 8 months now and I have not had any problems. I would say LS turbo or any other B series with a turbo but LS would probably be your cheapest bet. Just remeber to get a wastegate with a low boost spring in it. Then just leave your boost controller home and you wont have any problems. Thats what I do so I dont turn it up on a daily basis.</TD></TR></TABLE>
that's great advice regarding the boost controller...you never know, you might get itchy and want to crank up the boost...that could lead to problems...
Old Jan 15, 2004 | 09:24 AM
KRiS1's Avatar
B18C5 would probably be more reliable depending on the condition of the motor you get. The LS turbo would be fun,quick, and reliable if you build it right and don't tun the boost up to high.
Old Jan 15, 2004 | 09:25 AM
976's Avatar
976
New User
Default Re: Type R or LS Turbo in a CIVIC (KRiS1)
LS T - All you need is an eagle block guard... 6 daily/11 track psi...
Old Jan 15, 2004 | 09:26 AM
photec2's Avatar
Default Re: Type R or LS Turbo in a CIVIC (rewsnaeht)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewsnaeht &raquo;</TD></TR><TR><TD CLASS="quote">turbo LS for SURE. </TD></TR></TABLE>
werd thats what im going for
Old Jan 15, 2004 | 09:29 AM
amir's Avatar
it all depends on what your looking for track,1/4 mile,street......
Old Jan 15, 2004 | 09:37 AM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewsnaeht &raquo;</TD></TR><TR><TD CLASS="quote">heh. a turbo LS @10psi PROPERLY TUNED will be just as reliable as a type-r. also if you happen to blow it, throw a new shortblock in for DIRT cheap </TD></TR></TABLE>
he's right.....i've had my C1 turbo'd for over four years now,and it's just as reliable as when i first got it.assuming your motor is in good condition to begin with,and you keep up on the maintenance,you should have no problems.
chris
Old Jan 15, 2004 | 09:51 AM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
Default Re: Type R or LS Turbo in a CIVIC (TeamNextGenChris)
fos ho go wif da ls homie and build that **** wif like 8:5:1 and then be boostin like 20 and run like 11 or 12s dawg fo sho. lol
Old Jan 15, 2004 | 09:53 AM
976's Avatar
976
New User
Default Re: Type R or LS Turbo in a CIVIC (phaeded)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phaeded &raquo;</TD></TR><TR><TD CLASS="quote">fos ho go wif da ls homie and build that **** wif like 8:5:1 and then be boostin like 20 and run like 11 or 12s dawg fo sho. lol</TD></TR></TABLE>
No need to rebuild, an LS already has low compression...
