SKUNK2 cam gears or orhadox?? and i need some information aboutt the APEXI vtec controller
Old Sep 30, 2001 | 09:09 AM
JdoggsGSR's Avatar
New User
Default SKUNK2 cam gears or orhadox?? and i need some information aboutt the APEXI vtec controller
Hey was up im doing cam gears in my car im dont know if i should go with Skunk2 or Orthadox cam gears?? And im doing the Apexi Vtec controller is it worth it and hard to play with???? please send as many things about this topic im clueless
Old Oct 14, 2001 | 06:35 PM
SpeedRacer00-667's Avatar
Default Re: SKUNK2 cam gears or orhadox?? and i need some information aboutt the APEXI vtec controller (Jdog
NERD, NERD, NERD,NERD, NERD, NERDNERD, NERD, NERD,NERD, NERD, NERDNERD, NERD, NERD,NERD, NERD, NERDNERD, NERD, NERD,NERD, NERD, NERDNERD, NERD, NERD,NERD, NERD, NERDNERD, NERD, NERD,NERD, NERD, NERDNERD, NERD, NERD,NERD, NERD, NERDNERD, NERD, NERD,NERD, NERD, NERD.......get a turbo.........
just kidding
good luck w/ it
W_
Old Oct 14, 2001 | 07:11 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
No matter what gears you get, be sure to use Loctite on the bolt threads so they don't slip. VAFC... don't waste your money unless you get or have cams. And when you do get a VAFC, get it tuned professionally on a dyno. I had my gears, fuel pressure and VAFC tuned on the same day on a dyno.
Old Oct 14, 2001 | 07:24 PM
rockwilda's Avatar
i voted skunk2...
off topic but when you use loctite, which bolt are you talking about? the ones that goes innto the camshaft? or the ones surrounding it?
Old Oct 14, 2001 | 07:30 PM
Gee3's Avatar
The ones that go into the cam gear itself. ie - the Skunks have 6 bolts in their gears. Use Loctite on all 6 of those bolts for each cam gear. You may even want to out a dab on the bolt that goes on the end of the cam shaft as well, just to be safe.
Old Oct 14, 2001 | 08:15 PM
rockwilda's Avatar
one more question, so how are the gears tuned exactly?
Old Oct 14, 2001 | 08:18 PM
inochi's Avatar
New User
Is it true that apexi vtec controller has problems with the newer engines, 99-01. My friend got it on his 00 civic si and he told me he was just having non stop problems with it
IntegraGSR23
Feb 24, 2003 02:06 PM
B00ST2nR
Aug 15, 2002 12:14 AM
(__________)
Jul 30, 2002 07:56 PM
After_Burner
Feb 6, 2002 06:33 PM
