F/S 91 civic hatch w/ b16a sir II, SD, california
For sale 91 civic dx hatch w b16a sir 2. apporx 30,000 miles clean title. registration expired in oct 03.The engine swap was purchased from steve @ HMO. came from a 92 honda integra Xsi (jdm). I have not finished the swap yet so the car will need to be towed. the only thing that needs to be done is the shift linkage needs to be modified(you will get 2 shiftlinkages. the one that came with the car and the one that came with the swap.) also you will need a set of non obd injectors( you will recieve 4 obd1 injectors) also you will need to get a bung weilded into the jdm 4:1 exhaust manifold(header) for the second o2 sensor or just buy aftermarket header. the vaccum lines need to be connected.(i have printouts of the b16 vaccum diagrams) all the wiring has been completed...dx harness modified by SALBAJE h-t member.
you will also recieve 2 chiltons manuals; one for the dx that i bought. and another for the usdm b16a del sol.
Engine: 170hp 10:4:1 cr cable tranny YS1 pr3 ECU.
Place racing engine mounts
JDM B16 sir II
YS1 Cable Tranny
PR3 ECU
ADR intake w/K&N cone filter
ADR adjustable coilovers
Monroe Sensa-Trac Gas StrutsIII
DC Sports Short Throw Shifter
N1 apexi mufler w/scilencer
ngk plugs
9.3mm plug wires
sylvania cool blue headlights 9006/9005 conversion
panasonic head unit w/remote
4 pioneer 80 watt componet speakers
OBX/nippon steering Wheel
5 in tach w/shift light
also you will be getting a driver side dual mount guage pod with a oil pressure and oil temp guage (reverse indiglo) that has yet to be hooked up.
IM asking 3500 for the car. email me @ paybac4223@yahoo.com or pm me with questions...
Modified by paybac4223 at 3:27 PM 1/14/2004
Modified by paybac4223 at 3:33 PM 1/14/2004
Modified by paybac4223 at 7:29 PM 1/14/2004
Modified by paybac4223 at 7:33 PM 1/14/2004
Modified by paybac4223 at 10:44 AM 1/15/2004
JDM B16 sir II
YS1 Cable Tranny
PR3 ECU
ngk plugs
9.3mm plug wires
madskilz98
Sep 25, 2008 09:17 PM
paybac4223
Jan 15, 2004 09:57 AM
