Throttle Body?
Old Jan 14, 2004 | 11:35 AM
jdmcivicferio's Avatar
Default Throttle Body?
Which BBK throttle body will fit on a h22 motor from bbk
1546 - 62mm Honda Performance Throttle Body 1.5/1.6L
1547 - 70mm Honda/Acura Performance Throttle Body 1.8L/1.6L
1752 - 70mm Integra GSR Dual-Cam VTEC Throttle Body
1753 - 70mm 1996-2001 Integra Type-R Throttle Body
I am thinking part number 1547, but I just wanted to confirm thanks.
Old Jan 14, 2004 | 11:38 AM
2kflamedlude's Avatar
Default Re: Throttle Body? (jdmcivicferio)
why dont you just get an STR throttle body?
Old Jan 14, 2004 | 12:12 PM
Default Re: Throttle Body? (2kflamedlude)
because bbk are better, but thats beside the point...... Im 99% sure its the integra one, anyone 100% sure?
Old Jan 14, 2004 | 12:21 PM
Integra will work.. I would not neccessarily say that bbk are better thats more geared towards mustangs and such... I know im a Mustang fan also..
Old Jan 14, 2004 | 01:55 PM
ya I found out it is the integra one 100%, i am not geared towards bbk because of there mustang quality, more on the fact at there throttle body's made them who they are today they are good price/quality, I can't see myself buying a edelbrock, str etc. There just all junk once you start playing with them even the casting sucks, but now i'm just ranting.....
but thanks for the input guys!
if anyone cares it was the integra one that fit on the h22
Old Jan 14, 2004 | 03:36 PM
Bs2kB6
Guest
Posts: n/a
what is the stock size of the h22a throttle body?
Old Jan 14, 2004 | 03:40 PM
see_our_vtec's Avatar
Default Re: Throttle Body? (Bs2kB6)
stock h22=60mm
all of those tb's above listed will work on allmost any honda intake manifold.
Old Jan 14, 2004 | 03:58 PM
Bs2kB6
Guest
Posts: n/a
Default Re: Throttle Body? (see_our_vtec)
how much does a 70mm throttle body cost? lets say STR? and is it something tha twill help out a lot on a turboed prelude? or just good for airflow? i mean you know how with an N/A setup, you will see increase in hp, if it is on a turboed prelude W/OUT upping the boost or changing anything else would the whp go up just by changing it a little bit or is it just good for airflow at higher psi?
Old Jan 14, 2004 | 04:11 PM
YES it will help it out.
Old Jan 14, 2004 | 04:26 PM
Bs2kB6
Guest
Posts: n/a
well yea i konw it will help, but in what way. as in more airflow for upping hte boost later on, or is it like N/A where you will see some gains w/out boosting more or doing anything else. get what im saying? or not explaining it well enough.
Old Jan 14, 2004 | 05:10 PM
You will see a big gain with HEAVY modded NA.. Mostly on Domestic car though and for boosted you will see some HP increase.. I will be getting 70 throttle body for mine.. When I switch over to a supercharger.
Old Jan 15, 2004 | 10:18 AM
Wiseguy619's Avatar
I got my 68mm STR TB for $250 if I remember right. If you port it to match your IM, then it will produce much better air flow. If you do not port it to match your IM, then might as well keep it stock because air flow would be smoother that way.
Old Jan 21, 2004 | 09:14 AM
killa_lude's Avatar
Default Re: Throttle Body? (cleancrx909)
a skunk2 mani for what motor...?
Old Jan 21, 2004 | 12:08 PM
SKDRCR's Avatar
Default Re: Throttle Body? (killa_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude &raquo;</TD></TR><TR><TD CLASS="quote">a skunk2 mani for what motor...?</TD></TR></TABLE>
h22 j/k
Old Jan 21, 2004 | 02:23 PM
hOndafienD 04's Avatar
would i benifit from a bigger throttle body with basic bolts ons? c.a.i., headers, cat-back, etc...
Old Jan 21, 2004 | 08:28 PM
killa_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleancrx909 &raquo;</TD></TR><TR><TD CLASS="quote">its a b16 motor</TD></TR></TABLE>
oh, i would think that pretty much any tb would bolt up to the skunk2 mani...
Old Jan 22, 2004 | 03:39 PM
yes any honda throttle body will fit onto a skunk2 manifold, but the thing you want to make sure of is if you have a 70mm throttle body and a 65mm intake manifold, you have a bottle neck effect. So you have to make sure both sides are equal or get it port matched to fit right.
Old Jan 26, 2004 | 02:10 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleancrx909 &raquo;</TD></TR><TR><TD CLASS="quote">HOW MUCH IS TO PORT MATCH UR INTAKE MANIFOLD?? ANY PLACES IM FROM OC</TD></TR></TABLE>
ever heard of caps lock??
TURN IT OFF!!!!!!
and then read HT's rules.
Old Jan 26, 2004 | 05:18 PM
vietboi9's Avatar
i bought a str throttle body AND WHEN I PUT IT IN MY CAR WONT crank do why??
Old Jan 26, 2004 | 06:20 PM
Default Re: Throttle Body? (vietboi9)
did you set the tps?
Old Jan 26, 2004 | 07:06 PM
Wiseguy619's Avatar
I got quoted at $65 for a TB to IM port to match from a shop in SD.
Old Jan 27, 2004 | 05:21 AM
killa_lude's Avatar
Default Re: Throttle Body? (ProjectPenny)
inlinefour.com has some good overbored/big bore tb's!
Old Jan 28, 2004 | 04:21 AM
killa_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleancrx909 &raquo;</TD></TR><TR><TD CLASS="quote">do u know if a jg tb for gsr will fit a skunk 2 manifold</TD></TR></TABLE>
should
Old Jan 28, 2004 | 11:15 AM
VTECRaZeR's Avatar
Will a bigger throttle body work good with a C.A.I. orginally made to fit the stock one?
Or would you have to get a wide C.A.I. ?
Old Jan 28, 2004 | 08:12 PM
crj_lll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">ya I found out it is the integra one 100%, i am not geared towards bbk because of there mustang quality, more on the fact at there throttle body's made them who they are today they are good price/quality, I can't see myself buying a edelbrock, str etc. There just all junk once you start playing with them even the casting sucks, but now i'm just ranting.....
if anyone cares it was the integra one that fit on the h22</TD></TR></TABLE>
Which Integra one? Is this a stright bolt on? Does this mean any aftermarket throttle body for the integra will fit as well? What is the largest throttle body anyone has seen on an H22?
