timing belt life
Old Sep 29, 2001 | 11:35 PM
itr980923's Avatar
New User
Default timing belt life
can someone tell me what's the life of a 92 civic? just bought it used in a honda dealer, the original owner's changed the belt once and now with 215,000km(canadian spec) on the odometer. No idea when the first time was changed, and don't know if the 2nd time belt change was done. So, what's the tipical life time of honda timing belt? asking the used car sellsman seems useless aftersell.
Old Sep 30, 2001 | 06:37 PM
Gasoline Fumes's Avatar
Default Re: timing belt life (itr980923)
With the proper tension, it should be good for more than 100,000 miles. But, a $14 part capable of doing so much damage when it fails should be changed more often. If the belt is frayed, oily or cracking it's definetely time to change it.
Old Sep 30, 2001 | 07:34 PM
91ED7Si's Avatar
as a safe measure when ever you buy a new car you should imediatly change the timing belt just so you know when it was changed and you wont be worried about it snapping at any moment.
Old Oct 1, 2001 | 07:26 AM
crxgurlllll's Avatar
Default Re: timing belt life (91ED7Si)
I changed mine right when i got the car...but the damn thing was almost new!
Old Oct 1, 2001 | 06:51 PM
fixhondas's Avatar
Default Re: timing belt life (Gasoline Fumes)
A 14$ part?? LMFAO! Nothing but the best for you!
I would use only Honda belts (Unitta or Suregrip) or at least get a damn Gates belt. Honda belt is good for 90k miles or 6 years. If your **** is leaking oil at the cam or crank then the belt life will be significantly shorter. Rubber does not like oil. You could remove the valve cover and top belt cover and see how much slack is in the belt- it should not be very loose. We replace the drive belts with the Tbelt and you can "usually" guage belt condition by looking at the ribs on the drive belts. Again- use honda belts (Bando or Mitsubisho) or at least gates. IF you are unsure- replace it.
Old Oct 1, 2001 | 07:22 PM
Default Re: timing belt life (fixhondas)
Maybe it was $18. It's from http://www.hparts.com, and has "HONDA" written on it. I bough a Honda for its reliabilty, I wouldn't put crappy parts on it and turn it into a Chevy.
[Modified by Gasoline Fumes, 8:24 AM 10/3/2001]
[Modified by Gasoline Fumes, 8:25 AM 10/3/2001]
Old Oct 1, 2001 | 07:29 PM
One8Hatch's Avatar
New User
hey, that hparts.com link doesnt work, 18 bucks man i payed 60 at the local acura
Old Oct 1, 2001 | 10:34 PM
brad.'s Avatar
Default Re: timing belt life (One8Hatch)
whoa....ri-ri-ripped...
that's why I have 3 friends who work at Acura
and an uncle who's a tech at Honda
woohoo $30 OEM water pumps!!!!!
[Modified by [626]JDM-b16a-EF9, 7:34 AM 10/2/2001]
Old Oct 2, 2001 | 11:27 PM
chibiko
Feb 22, 2007 05:45 AM
gator88
Jun 19, 2005 08:50 PM
Fink2iCe
Oct 6, 2004 09:23 PM
armharm
Nov 8, 2002 02:57 PM
dogpile5
18
Nov 6, 2002 09:01 AM
