Legend caliper brake swap?
Old Jan 14, 2004 | 07:01 AM
egizzle8
Guest
Posts: n/a
Default Legend caliper brake swap?
Has anyone ever done this swap with legend calipers and using redrilled 4 bolt prelude rotors? The legends have 2piston calipers and the older nsx's are pretty much the same(actually smaller) but the pads are like way more. Also the rotors from a g60 Corrado can be use but a spacer will have to be use cause the offset is a little different but for like $60 for a set of 11" rotors from autozone with a lifetime warranty can't be passed up. Just wondering
Old Jan 14, 2004 | 07:07 AM
DIY_Racing's Avatar
Default Re: Legend caliper brake swap? (egizzle6)
Yes id like to know this to.
WHat year legend caliper?
What rotor with the legend caliper?
Come on brake gurus..
Old Jan 14, 2004 | 07:19 AM
egizzle8
Guest
Posts: n/a
Default Re: Legend caliper brake swap? (DIY_Racing)
mid 90's GS(Anything with V6) plus some material has to be machine of the the caliper or it'll rub. The 4 lug prelude will work but just have to be redrill for a 4x100 pattern.
Old Jan 14, 2004 | 07:49 AM
creechrr's Avatar
I think Emerika did something similar to this. You might want to check some of his old posts.
Old Jan 14, 2004 | 08:14 AM
egizzle8
Guest
Posts: n/a
Default Re: Legend caliper brake swap? (creechrr)
Yeah but he used the Accord wagon calipers(same as one as ITR) or something like that. I remember the post cause it was very informative non the least but it's using using a one piston caliper. So I was wondering if the larger caliper would need you to change to a bigger MC or what?
Old Jan 14, 2004 | 08:18 AM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIY_Racing &raquo;</TD></TR><TR><TD CLASS="quote">Yes id like to know this to.
94-95 Legend cpe ONLY has the two piston setup you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIY_Racing &raquo;</TD></TR><TR><TD CLASS="quote">What rotor with the legend caliper?
most use Prelude VTEC 11" redrilled to 4 x 100mm.
Old Jan 14, 2004 | 08:23 AM
DIY_Racing's Avatar
Default Re: Legend caliper brake swap? (Doctor CorteZ)
Vtec prelude rotor?? 92-99 will work??
Thanks.
Old Jan 14, 2004 | 08:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIY_Racing &raquo;</TD></TR><TR><TD CLASS="quote">Vtec prelude rotor?? 92-99 will work??
92-95 VTEC is what you want , the 4 lug ones.
I dont like the 5 lugs since you have to elongate one of the holes to get a 4x100 pattern out of them.
Old Jan 14, 2004 | 08:43 AM
slammed_93_hatch's Avatar
i did a similair setup to this except i went over to the 4x114.3 side. no matter what rotor you use (from my expereance) you will have to either shim or grind.
now there maybe some wheels out there (te37 i have heard are awsome for clearing big calipers) but i don't know. the only thing that turned be off from useing the 2 piston caliper, is how much has to be ground off (around 7-8 milimeters i have heard). and my dumb *** couldn't figure out were to put the shims some people use. but if i ever run into some one that knows how to do the shims id get myself a set of the older NSX calipers that say NSX on them and slap them on the car, id love the bling and the better clamping power
Old Jan 14, 2004 | 08:47 AM
egizzle8
Guest
Posts: n/a
Default Re: Legend caliper brake swap? (slammed_93_hatch)
THere was a guy in the ef forum that slapped NSX on his crx and has a nice write up and pics. It's just that its easier and cheaper to find legend calipers than NSX ones. There are pretty much the same but the legends are actually a little bigger than the NSX of the mid 90's years.
Old Jan 14, 2004 | 08:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 &raquo;</TD></TR><TR><TD CLASS="quote">There are pretty much the same but the legends are actually a little bigger than the NSX of the mid 90's years.</TD></TR></TABLE>
and when you flip sides on the NSX calipers the differential bore is backwards , which is bad if you track your car at all and would lead to very strange and accelerated pad wear.
FYI - I've had both and they are identical in weight , only thing different is the bore size and location of the bleeder , oh and the NSX's say NSX in raised letters.
dartdc97
Oct 13, 2006 09:25 PM
dartdc97
Oct 10, 2006 12:05 PM
ahki
Aug 6, 2002 01:49 PM
Jordan_4WS
Apr 10, 2002 04:27 PM
