Roll bar ?
Old Jan 14, 2004 | 06:49 AM
egizzle8
Guest
Posts: n/a
Default Roll bar ?
Anyone ever heard of S & W roll bars? They have them for 149 for a 8pt setup or like 220 for a 10pt. They exceed NHRA, IHRA & NMCA requirements but would they pass SCCA? Plus the 10-point roll cages are designed to remain behind the firewall and require no modifications to the stock dashboard. THey make em for EF,EG, and EKs.
Old Jan 14, 2004 | 07:05 AM
civicminded92's Avatar
Default Re: Roll bar ? (egizzle6)
What class would you be running in that would require a roll bar? Or, are you worried that you would be bumped up to a higher class is you do run one?
The rules for solo 1 for roll bars can be found in the following link:
(The list to the right is for a specific roll bar, but the right would be applicable to any bar)
http://www.teammiata.com/libs/...S.pdf
You could do some research to determine wheter the NHRA, IHRA, and NMCA requirements are similar. At least I got you started.
Happy hunting!
Old Jan 14, 2004 | 07:07 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
ive seen their site too was thiking about it...in fact i think ijust might go ahead and get it!!!!!!!
Old Jan 14, 2004 | 07:09 AM
egizzle8
Guest
Posts: n/a
Default Re: Roll bar ? (civicminded92)
It doesn't require one but I just like the safer feeling then just the airbag and harness. Plus I'd feel a little better having a bar beside the harness bar. Plus 220 for a cage you can't go wrong with not having to **** your dash or 150 for the 8pt. Either way you can't lose.
Old Jan 14, 2004 | 07:24 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
but the question is how much for shipping thats gonna run you
Old Jan 14, 2004 | 07:25 AM
Well, if it's not a requirement for you to have one, you should be ok with whatever bar. Wouldn't make any sense to say, "Well you don't have to have a bar, but if you do it must pass our stringent requirements!" The only thing that might dock you is that if you put it in there without securing it - and why would you do that?
Old Jan 14, 2004 | 07:27 AM
hondachick81's Avatar
I have found through recent searching that the bar must be ERW or DOM tubing...
a recent discussion was in the race forum.... there are some links to particular rules, like SCCA and NASA...check it out! It helped me
https://honda-tech.com/zerothread?id=726981
Old Jan 14, 2004 | 07:31 AM
egizzle8
Guest
Posts: n/a
Default Re: Roll bar ? (civicgirl114)
It was like 80 for the 10 point or 60 for the 8pt. Still thats pretty cheap.
allmtrdc4
Mar 12, 2006 05:34 PM
hybrid901
Honda S2000
12
Aug 16, 2004 04:30 AM
b18cx
Feb 27, 2004 11:15 AM
b18cx
Feb 8, 2004 03:58 PM
DubyaAye
May 16, 2003 09:42 PM
