Front Bumper Removal
There are also two 10 mm screws I believe that are in the wheel well area that need to be removed as well. You have to take out your front blinker lights to get access to the two main bolts on each side. (Under the headlight).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord_Munch »</TD></TR><TR><TD CLASS="quote">There are also two 10 mm screws I believe that are in the wheel well area that need to be removed as well. You have to take out your front blinker lights to get access to the two main bolts on each side. (Under the headlight).</TD></TR></TABLE>
i think they are 12mm behind the bumper blinkers too..
Fleas_Ef
Jan 18, 2005 07:46 AM
