building engine
Old Jan 13, 2004 | 10:13 PM
joeyandhiscrx's Avatar
Default building engine
i got a b16 in my crx. i want to run atleast 13's. i was wondering if someone could tell me which mods would help out the most and wouldnt harm my engine. i dont want any force induction like nos or turbo.what should i get besides the basic bolt ons besides intake, headers opr exhaust?
Old Jan 13, 2004 | 10:26 PM
SimbaDogg's Avatar
Default Re: building engine (joeyandhiscrx)
if you're wanting to run that @ least a 13.999 which would be very easy to do, you have to do a few things especially if you wanna stay away from FI, N20.
TRACTION, TRACTION, TRACTION
make sure u have a good tranny, w/ decent gear ratios for your settup, and a LSD and lightened flywheel would do wonders for you '60 and 1/4 time. really, an lsd will be needed especially if you want those faster times w/ a FWD. i'd say go w/ the basic built head (cams, valvetrain, etc). other than that, some lightening of the vehicle would help. cf hood etc, and lighter wheel tire combo w/ stickier compounds is always a plus.
Old Jan 14, 2004 | 03:15 AM
civickiller's Avatar
Default Re: building engine (SimbaDogg)
type r cams, pistons and intake should get you in the 13s
Old Jan 14, 2004 | 03:43 AM
Davep's Avatar
Default Re: building engine (civickiller)
You don't want to put the ITR pistons in killer, it will lower your CR.
Old Jan 21, 2004 | 12:54 PM
Default Re: building engine (Davep)
wait...so are the itr cams good or no?
what kinda pistons should i get?
Old Jan 21, 2004 | 01:10 PM
Malgerus's Avatar
Don't worry about the pistons.
Here's a nice little recipe for 13's:
An Intake
Header
Exhaust
ITR Intake Manifold with bigger throttle body
ITR Cams and valvetrain
Lighten Car
Good tranny, good traction
Easily 13's.
Old Jan 21, 2004 | 01:48 PM
Kasper.'s Avatar
Default Re: building engine (Mr. S)
I heard the CTR intake cam is a nice upgrade for cheap.
But I read somwhere a guy did just a Jun (dont know what stage) intake and it made a world of diff. compared to Toda intake and exhaust.
Whatever you do, stay small with things seriously to many guys on here put on big as intakes and exhausts, our cars lack torque which is increased by velocity, our cars already have plenty of flow both intake and exhaust.
Just keep that in mind, basic bolt-ons will help but be choosy and dont get things that everyone else has, dont be afraid to do alot of customization as far as intake and exhaust goes.
Old Jan 21, 2004 | 11:08 PM
SimbaDogg's Avatar
Default Re: building engine (KasperFFTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KasperFFTI &raquo;</TD></TR><TR><TD CLASS="quote">I heard the CTR intake cam is a nice upgrade for cheap...</TD></TR></TABLE>
yeah...thats what they say, but people who say that can kiss my ***. seriously, the gains that you're gonna get w/ that as opposed to a regular ITR aren't even worth the extra money you're gonna spend for that CTR intake cam. Spend it on ssomething else. Some places charge 350 for that intake cam, and only 275 for the ITR (new) the shiet AINT worth fuggin 75 bucks
Old Jan 21, 2004 | 11:16 PM
4inspeed's Avatar
use ctr parts,
i would say:
ctr cams
itr valve springs (or ctr)
ctr pistons
itr intake man.
that right there will get you into the 13's easy.
Old Jan 23, 2004 | 02:02 AM
Default Re: building engine (4inspeed)
whats so good about the itr intake?and i sound dumb as hell saying this but ctr means civic type r right/
Old Jan 23, 2004 | 02:12 AM
Sleepin Crx's Avatar
ctr cams all the way
they are more aggressive then the itr cams
Old Jan 23, 2004 | 02:28 AM
4inspeed's Avatar
Default Re: building engine (Sleepin Crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepin Crx &raquo;</TD></TR><TR><TD CLASS="quote">ctr cams all the way
they are more aggressive then the itr cams</TD></TR></TABLE>
not true, only 1 cam is different the other is the exact same, and your not really gonna get great gains out of them unless you raise the comp. hence ctr pistons, yes ctr stands for civic type r.
Old Jan 23, 2004 | 02:36 AM
?? well a few honda guys i chill with have gotten 5-8whp by puttin them in on the dyno, for 200 bucks cdn, thats not bad on say a crx.... well on a b16a1 the comp is 10.4:1, thats pretty high....
and yeah its pretty obvious ctr stands for civic type r........
what does vtec stand for?
Old Jan 23, 2004 | 03:10 AM
4inspeed's Avatar
yes 5-8 whp isnt bad.... but with a comp ratio closer to 12:1 you will get MUCH more impressive gains.
Old Jan 23, 2004 | 09:32 AM
xci_ed6's Avatar
Default Re: (OOsi)
Use type R intake valve springs on the exhaust side. Use stock intake valve springs.
Type Rs got lighter valves, so the springs are lighter. The intake valve is larger (and so heavier) so the intake valve spring will be stiffer than the exhaust spring.
B16s did not come with dual exhaust springs, but did come with dual intake springs, so only the exhaust springs need changed.
Info I found and have not tested, but it was a reliable source for other info.
For an intake mani, look for a Typhoon (can't remember company) it has gotten great results for $150. It is like a typeR w/ a slightly longer plenum to feed cylinder 1 better.
-Dustin
Old Jan 23, 2004 | 10:34 AM
4inspeed's Avatar
Default Re: (OOsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OOsi &raquo;</TD></TR><TR><TD CLASS="quote">ctr pistons 12:1 compression, with an itr IM/throttle body, and itr intake cam, AEM V2, Thermal Stealth cat back itr header, setup on my Si making 185whp, making low 13's consistatnly with full interior, and keep in mind its a much bigger EK</TD></TR></TABLE>
what exhaust cam are you running? stock? nice setup btw
Old Jan 26, 2004 | 10:11 PM
Default Re: (4inspeed)
so would ctr cams be worth it instead of getting itr cams....is the money difference worth it?
Old Jan 26, 2004 | 10:32 PM
SimbaDogg's Avatar
Default Re: (joeyandhiscrx)
no, spend it elsewhere
Old Feb 1, 2004 | 09:59 PM
Default Re: (SimbaDogg)
should i get the itr intake mani...will that make a difference?
Old Feb 1, 2004 | 10:17 PM
kanzenr91si's Avatar
i dont think you can im yet so email me. i have everything youve been askin about. kanzenr91si@aol.com
or if youre like me and took forever to change your newbie pic, im me.
The G2 Racer
11
Apr 7, 2004 04:03 PM
curt801
Dec 6, 2003 09:37 AM
xsnrgsr
Aug 15, 2003 11:38 AM
WildMan541
May 16, 2003 02:39 PM
JDM CRX
Sep 13, 2002 09:24 PM
