Do It Yourself? Removing stock tires off stock wheels.
Old Sep 29, 2001 | 06:13 PM
BlueG3Teg's Avatar
New User
Default Do It Yourself? Removing stock tires off stock wheels.
Hey guys, how hard is it to remove stock Michelins off the stock wheels.
Is it possible to Do it yourself or do you have to bring it to a tire shop to remove them.
If its possible to DIY, can somebody tell me the procedures and what tools I need.
Thanks
Old Sep 29, 2001 | 07:18 PM
Rain_man's Avatar
New User
Default Re: Do It Yourself? Removing stock tires off stock wheels. (BlueG3Teg)
I suppose if you really want to get them off yourself you could just cut up the tires, except for the tire bead which will probally require a hacksaw to bolt cutter to cut. All in all, I'd say it's not worth it, tires are not designed to be removed without a machine. Tire shop shouldn't charge you more than 10-20 dollars to have the tires removed. I paid 40 dollars to have my tires removed, new ones put on and have them balanced.
Old Sep 29, 2001 | 08:20 PM
fangtl's Avatar
Default Re: Do It Yourself? Removing stock tires off stock wheels. (Ein)
Not DIY considering how much time it'll take. Pay someone to do it
Old Sep 30, 2001 | 03:43 AM
BlueG3Teg's Avatar
New User
Default Re: Do It Yourself? Removing stock tires off stock wheels. (fangtl)
Wow I thought the stock Michelins were soft enoguh that you can slip it off yourself. I guess not then.
Old Sep 30, 2001 | 07:46 AM
lucas569's Avatar
all wheels have a double bead,its a safety item. its very difficult to remove a tire w/ out the proper machine. if your getting new ires installed they usaully dont charge to remove them anyhow,just mount and balance. in many stores the fee is waived if your buying 4 tires.
j-rome
10
Dec 20, 2008 07:09 PM
maryeliza
Honda Fit
Nov 9, 2007 04:53 PM
boostincoupe
Feb 8, 2006 10:57 AM
Mr.E.G.
20
Apr 21, 2004 12:27 PM
Muckman
Sep 28, 2001 06:15 AM
