will B series vtec distributor work on B series NON vtec
Old Jan 13, 2004 | 08:39 PM
KevronsEG's Avatar
Default will B series vtec distributor work on B series NON vtec
i have b18b and teh dist is bunk so i got a spare b16 dist. will it work or no
Old Jan 13, 2004 | 08:53 PM
Turbogixxer's Avatar
Default Re: will B series vtec distributor work on B series NON vtec (CIV616)
It will be the same as if you put a non-vtec dizzy on a vtec head. It will work, but not all the holes/bolts will line up.
Old Jan 14, 2004 | 06:23 AM
KevronsEG's Avatar
Default Re: will B series vtec distributor work on B series NON vtec (turbogixxer)
thanks bunch
Old Jan 14, 2004 | 07:16 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
u might have to cut an "ear" off i know vice versa you do...
Old Jan 14, 2004 | 10:56 AM
b16turbohatch's Avatar
you can take out all the inside's and transfer them i had to do it all the inside's are the same but the housings are different
Old Jan 14, 2004 | 02:20 PM
SYD's Avatar
SYD
Default Re: (b16turbohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16turbohatch &raquo;</TD></TR><TR><TD CLASS="quote">you can take out all the inside's and transfer them i had to do it all the inside's are the same but the housings are different</TD></TR></TABLE>
yes this is very true...check and see whether its the ignitor, coil, or bearing etc..just incase u can salvage some of the spare parts from the old dizzy for a rebuild in the future maybe..
markviiisvt4
Oct 17, 2007 08:08 AM
Dabber
Jun 29, 2007 11:24 AM
jdmcivicferio
Sep 25, 2003 11:28 AM
lowcivex
Mar 4, 2003 07:56 AM
