Octane Booster
Old Sep 29, 2001 | 05:40 PM
Import RP's Avatar
Default Octane Booster
I got some octane booster and dumped it in today, it felt like it performed a little better, but does it really make a difference? Is there anything you can just dump in your gas tank that can really add a decent amount of horsepower without hurting your engine?
Old Sep 29, 2001 | 07:14 PM
spyder's Avatar
New User
Default Re: Octane Booster (Pyrochaos38)
Octane booster (and high octane fuels for that matter) actually give you LESS power than you would normally have. The only reason to use high octane fuels is to keep detonation from occuring, and the only time you might detonate is if you are running very high compression, or some type of forced induction. at ALL OTHER TIMES use the LOWEST octane rating that is listed by the manufacturer OR the lowest that your car will run smoothly on. (No comment JG Luder, your car NEVER runs smoothly, darn cams... )
Old Sep 29, 2001 | 07:38 PM
thefungus's Avatar
New User
Default Re: Octane Booster (spyder)
wait.. so honda recommends Premium
but you should use the lowest you can
get away with?
also, why do honda and other car companys
recommend premium if detonation isnt an
issue?
any sites have a good explination of all this?
Old Sep 29, 2001 | 07:52 PM
Import RP's Avatar
So there is nothing you can dump in your gas tank that will add horsies?
Old Sep 29, 2001 | 08:20 PM
smokin rubber's Avatar
it is possible for octane to help an engine make more power, but only if timing is advanced or the engine is pinging or knocking <with a knock sensor>.
If you can get some dyno time and are going to use a set octane,a car with basic bolt-ons can be tuned for a few more horses.
Old Sep 29, 2001 | 09:11 PM
976's Avatar
976
New User
Default Re: Octane Booster (theFungusAmongus)
get away with?
issue?
Most stock honda engines aren't high compression...
[Modified by B21A, 6:12 AM 9/30/2001]
Old Sep 30, 2001 | 12:13 PM
JG Luder's Avatar
Default Re: Octane Booster (B21A)
H22A's are "high compression" motors. Even when I was stock my car always ran it's best on 93 and that was it. 91 or 92 and it had a... well, a "lag" before VTEC. Hard to explain.
Anyway, since everyone knows I have to use 1 bottle of octane booster for every 8 gallons of 93 octane just to make it to and from work with my timing retarded, I'll keep my mouth shut.
Old Sep 30, 2001 | 12:14 PM
JG Luder's Avatar
Default Re: Octane Booster (JG Luder)
By the way... Stupid Street did an AWESOME article on octane and octane boosters a few months ago. I'll try to find it this week sometime.
Old Sep 30, 2001 | 03:01 PM
Gabe's Avatar
That is absolutely not true. 93 octane fuel has the same amount of BTU's (i.e. chemical power) as 87 octane fuel but is mixed with addatives to resist detonation. Octane rating has absolutely nothing to do with power, it is simply a measure of the fuels resistance to detonation.
Gabe
Old Sep 30, 2001 | 07:02 PM
spyder's Avatar
New User
Default Re: Octane Booster (Gabe)
so it is simply a measure of the fuel's resistance to detonation huh? Okay, answer me this. Just HOW, pray tell, do those additives increase the fuel's resistance to detonation, O all knowing one?
Before you answer, I would like to point one thing out. JG Luder is known for jumping on incorrect information and chewing out whoever gave it. I know this from personal experience. If you will take a look at his post count and his car, I believe you will find that he might know just a little about engines and high compression. He didn't correct what I said, so think your answer through very carefully.
[Modified by spyder, 10:05 PM 9/30/2001]
Old Sep 30, 2001 | 08:35 PM
Gabe's Avatar
They increase their resistance to detonation by raising the temperature at which they burn. This is acheived by changing the bonding between atoms in the fuel. The stronger the bond the more enrgy it takes to break that bond and begin combustiuon. Now there is some minor loss in the chemical engery due to the addition of oxygenates to the fuel but the difference between the energy contained in 91 and 87 octane fuel is very small (less than 10%). If you added enough oxygenates to the fuel then you could acheive a large difference.
As for JG, yeah he's a pretty smart guy but that doesn't mean he knows everything. If you're basing the correctness of your answer on JG's non-response to yours then I think you're misleading yourself.
Gabe
Old Sep 30, 2001 | 09:17 PM
spyder's Avatar
New User
Very good. Higher octane fuels have (of course) a higher level of octane and a lower level of heptane than the lower grade fuels. As you said, there is some minor loss. Did I ever say there was a large loss? No, I just said there was a loss, and if I understand what you said correctly, you agreed that there is a loss.
No, I am not basing the correctness of my answer on JG's non-response, I was just pointing out that he had not corrected me when he usually corrects info he believes to be incorrect. Was not using it as a basis for anything, just as food for thought.
Old Oct 1, 2001 | 03:00 PM
bb6h22a's Avatar
Default Gasoline...
..is a mixture of various hydrocarbons of varying lengths, and are not neccessarily mixtures of say 87% Octane and 13% Heptane, althogh they could, but for fiscal reasons they most likely arent. Hence, the term "octane" is an arbitrtary one used for reference or bookeping if you will, b/w varying blends of gasoline. For example, if you were to compare gasoline a vs. gasoline b. vs. gasoline c, you would use the octane term/rating in qualitativly assesing that gasolines resistance to knock in reference to octane itself, or a given mixture of octane blended w/ heptane.
So, like gabe pointed out, the utility of high octane gasoline is the anti-knock propertyor deterering fuel ignition by compression. And as we all know the compression ratio of a given motor is what ultimatly generates the power and calls for the use of higher octane fuels, not the other way around.
[Modified by bb6h22a, 4:03 PM 10/1/2001]
[Modified by bb6h22a, 4:05 PM 10/1/2001]
Old Oct 1, 2001 | 03:13 PM
JG Luder's Avatar
Default Re: Gasoline... (bb6h22a)
Goddamned chemists.
Old Oct 1, 2001 | 03:47 PM
thefungus's Avatar
New User
Default Re: Gasoline... (JG Luder)
hahahahaha
Old Oct 1, 2001 | 04:47 PM
Gabe's Avatar
Sorry to have misunderstood you then, I thought you were saying there was a tremendous heating value difference between a high and low octane fuel. It can be argued that the loss is negligable though. As an engineering approximation they are probably assumed to have the same heating value.
Gabe
Old Oct 1, 2001 | 05:15 PM
Import RP's Avatar
uh, wow. So you guys would suggest I DONT use octane booster? Its not worth the money...?
Old Oct 1, 2001 | 05:38 PM
spyder's Avatar
New User
Nope, no real need for octane booster unless you are detonating on 93 octane or higher fuel.
Gabe: Yes, I definately agree that the losses are negligable...
Old Oct 2, 2001 | 12:44 PM
SIRPRELUDE92's Avatar
New User
SO WHAT IF YOUR MOTOR STOCK MIND YOU IS 11.0.1
[Modified by quicklude, 1:49 PM 10/2/2001]
Old Oct 2, 2001 | 02:29 PM
bb6h22a's Avatar
Default Well...
..considering the new M3 w/ 11.5:1 compression is sleighted for N. American sale, I would say that 91 octane should be sufficent, w/ 93 being optimal.
SlowEJ8
48
May 2, 2009 06:44 AM
-Championship-
Jul 12, 2006 07:23 PM
hondaracin24
Dec 20, 2004 06:38 PM
boostincoupe
Jun 25, 2003 05:53 PM
MintyDip
Aug 16, 2002 10:12 AM
