Wierd Noise Up Front.......
Old Jan 13, 2004 | 07:40 PM
Jester88Si's Avatar
Default Wierd Noise Up Front.......
Ok heres the deal when I say... brake hard or let off the clutch hard and quick I hear this loud POP up front I'm thinking axle but I wanna be sure any ideas? the car has 112k miles. Thanks
Old Jan 14, 2004 | 07:45 PM
hondaciv3's Avatar
Default Re: Wierd Noise Up Front....... (Jester88Si)
Free bumb
Old Jan 14, 2004 | 07:56 PM
Cory man's Avatar
Default Re: Wierd Noise Up Front....... (hondaciv3)
Have you looked up under the car? A popping sound can be lots of things. In order to diagnose exactly whats wrong you will have to at least narrow it down somewhat. Good luck!!
Old Jan 14, 2004 | 08:12 PM
Lo-Buck EF's Avatar
Default Re: Wierd Noise Up Front....... (Cory man)
things to look at:
balljoints (upper and lower)
engine mounts
tension/compression rods
control arm bushings
Old Jan 14, 2004 | 11:25 PM
Jester88Si's Avatar
Default Re: Wierd Noise Up Front....... (Lo-Buck EF)
Ball joints look good so do control arm bushings....ill check the engine mounts next im stumped what and where are the tension/compression rods never heard that phrase before (go easy im 16 dont know too much yet )
Old Jan 15, 2004 | 08:34 AM
Lo-Buck EF's Avatar
T/C rods also known as radius rods. they go from your lca to the subframe and keep the lca from moving fore and aft.
Old Jan 15, 2004 | 08:44 AM
misledyouth_is_back's Avatar
had the same noise it was the upper ball joints. see if you can wiggle them forward and back if they have any play replace them.
jesse
Old Jan 15, 2004 | 10:28 AM
Jester88Si's Avatar
Default Re: Wierd Noise Up Front....... (misledyouth_is_back)
ok thanks fellas
alscrx
29
Aug 10, 2021 11:23 PM
smurf357
Jul 21, 2010 08:17 PM
rexfan
Jun 2, 2008 04:40 AM
ridestrt
May 18, 2004 09:27 AM
89civic1.8T
Aug 26, 2002 08:41 AM
