this has to do wit the cluster gauges
Old Jan 13, 2004 | 07:09 PM
vtekstorm's Avatar
Default this has to do wit the cluster gauges
im about to install indiglow face gauges on the cluster of my car. is there anything i should know before i do this. so i can do it rite the first time and not **** it up. and can i wire the positive and negative wires to the dimmer switch for the interior lights or should i wire it to the park lamp switch.
any advice or instructions would help alot thanx guys
Old Jan 13, 2004 | 07:14 PM
92civeg's Avatar
Default Re: this has to do wit the cluster gauges (vtekstorm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekstorm &raquo;</TD></TR><TR><TD CLASS="quote">im about to install indiglow face gauges on the cluster of my car. is there anything i should know before i do this. so i can do it rite the first time and not **** it up. and can i wire the positive and negative wires to the dimmer switch for the interior lights or should i wire it to the park lamp switch.
any advice or instructions would help alot thanx guys </TD></TR></TABLE>
dont take the needles off...wire the positive wire to your headlight fuse and ground the negative....be ready to get flamed
Old Jan 13, 2004 | 07:43 PM
vtekstorm's Avatar
Default Re: this has to do wit the cluster gauges (92civeg)
lol i know im gonan end up getting flamed but the gauges i have are not those bright *** green ones that can light up a street. the gauges are white when not turned on but turn blk when they are turned on and its the letters that shine up and the lines also. so how the **** do i get the face off that has the fuel and temp gauge
Old Jan 13, 2004 | 07:44 PM
92civeg's Avatar
you dont take it off u simply slide the cover over it
19da90
10
Feb 12, 2013 05:29 PM
MilanoEj1
Sep 27, 2010 09:52 PM
401tuner
Jun 7, 2007 09:11 PM
philkehn
Oct 12, 2006 05:54 PM
