HELP!! car won't start or starts and stalls.
Old Sep 29, 2001 | 03:42 PM
Lei Siew Long's Avatar
Default HELP!! car won't start or starts and stalls.
i took out and replaced the exhaust cam and have the shitty skunk sprockets. i lined the exhaust and intake cam to TDC on the number one piston with he hole on the cams and cam journal. had the crank on TDC as well from what i recall.
the holes on the cams were maybe 2/16 of an inch off from the cam journal hole at the most.
started up the car and heard the alternator belt squeeking, so i adjusted that and the squeeking stopped temporarily then after turning off the ignition the car won't start or it would start and stall immediately.
i don't believe it is the alternator or starter because both cranks but the engine just won't turn over. HELP!!.
thanks in adv
Old Sep 30, 2001 | 04:26 PM
clockworks's Avatar
Default Re: HELP!! car won't start or starts and stalls. (boostedeg6)
Perhaps the alt. harness came loose when you were tensioning the belt. Double check the timing too.
vr4twinturbo
Oct 27, 2006 08:46 AM
fast_honda
Feb 22, 2006 12:23 PM
92HB_HB
Feb 13, 2005 06:05 AM
