i just keep blowing fuses
Old Jan 13, 2004 | 04:50 PM
2K GSR's Avatar
Default i just keep blowing fuses
well i started blowing fuses in my power cable that go to my sub. It started when i put a new battery in my car. I have a Rockford Fosgate 750s powering one 12". I tried putting 30 amp fuses in them, and they blew instantly. i put a 60 amp fuse in there and it worked for about 5 minutes then blew. I checked the manual for the amp and it said it needed 60 amp fuses, but even the 60 amp one blew. i checked the battery connection it is tight, the power cable is fine, and the ground is tight, did i miss something or is it the amp for sure this time?
Thanks
Old Jan 13, 2004 | 05:51 PM
shibby's Avatar
Default Re: i just keep blowing fuses (2K GSR)
look over your whole power wire, from the battery to the amp, and make sure theres no cuts or anything. my guess would be its shorting out somewhere, most likely at the fire wall.
Old Jan 13, 2004 | 06:11 PM
pbcdb's Avatar
Diddo, the power strand must be touching metal somewhere. Check the back of the amp and make sure there isn't any strands hanging out.
Old Jan 13, 2004 | 08:26 PM
2K GSR's Avatar
Default Re: (pbcdb)
did that already, i checked the wire and it didnt ground itself meaning it didnt create a circuit
Old Jan 14, 2004 | 11:50 AM
nOOber's Avatar
Is your ground wire for the amp the same size as the power wire ?
Howz the ground connection at the battery ?
Old Jan 14, 2004 | 11:53 AM
2K GSR's Avatar
Default Re: i just keep blowing fuses (nOOber)
thats all good, its gotta be the amp now
Old Jan 14, 2004 | 11:59 AM
rcurley55's Avatar
New User
what is the coil config on the 12"....make sure you aren't trying to run it at 2 ohm mono or something strange like that....I'd use a dmm to double check it all...
Old Jan 14, 2004 | 12:04 PM
GAtegs's Avatar
Default Re: i just keep blowing fuses (rcurley55)
Yea, what is the sub you have? Brand/model?
Old Jan 15, 2004 | 08:11 PM
2K GSR's Avatar
Default Re: i just keep blowing fuses (NAPA182)
the sub model is a Rockford FOsgate HE2, turns out its a dual voice coil, and i re-wired it and so far it is working, im dumb *** the first time just hooked it up to one of the imputs, but then i read the manual and it told me how to do it right, huh should have thought about that the first time. anyways the ******* at best buy said a 30 watt fuse is fine, when i read the manual it required 60 watt, now its working fine for the past couple days, and actually hasnt sounded better, oddly enough.
Thanks for the help
Old Jan 15, 2004 | 08:17 PM
lillthingz's Avatar
Get a 80watt fuse they are a few bucks and kinda hard to find but any amp over 500 watts need a 80 i have one on my 600 watt amp.
NewtoCivics
Audio / Security / Video
12
Jan 11, 2012 04:28 AM
froogle29
Oct 29, 2009 07:44 PM
pooMan
20
May 22, 2006 09:10 AM
GZERO
Dec 26, 2005 09:52 AM
BoroDB8
Oct 15, 2001 01:09 AM
