Newbie w/ question about vacuum lines on a6
Old Jan 13, 2004 | 03:23 PM
ED6's Avatar
ED6
Default Newbie w/ question about vacuum lines on a6
I took my head off to replace my headgasket and now that Im putting it on, I cant remember where some of the lines go. If someone could take a picture of their intake manifold (an Si) or direct me to a diagram of some sort, that would be awesome. I used the search on here but found nothing useful.
Old Jan 13, 2004 | 03:39 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Newbie w/ question about vacuum lines on a6 (ED6)
what year model are we working on?
this is for an '88 model:
http://www.cartogra.com/servle...size=
This link is for a 1991:
http://www.binghamtonlife.com/...7.jpg
from here:
http://www.binghamtonlife.com/...t.htm
Modified by 88DXCRX at 11:03 AM 1/14/2004
Old Jan 13, 2004 | 03:50 PM
ED6's Avatar
ED6
Default Re: Newbie w/ question about vacuum lines on a6 (88DXCRX)
its an 89 Si with the a6 motor. The diagram you posted helped a bit but theres still a couple not shown off the back of the manifold.
Old Jan 13, 2004 | 04:05 PM
88DXCRX's Avatar
got a pic of the ones you aren't sure of?
Old Jan 14, 2004 | 07:21 AM
ED6's Avatar
ED6
Alright, I think I got all the lines where they should be. So I started it up and it idled real high (3,000rpm) I was getting a code 10 (IAT) so I unplugged the sensor and it idled a lot better but still pretty rough. I also noticed that there is coolant leaking from a little unit on the back of my intake manifold near the throttle body. What the hell is coolant doing up there? I didnt know it was routed anywhere near there. Anyone know what it is and why it might be leaking? I think it may be clogged for some reason.
Old Jan 14, 2004 | 08:01 AM
88DXCRX's Avatar
Coolant flows through the throttle body and into the EACV
that is "electronic air control valve" which helps control the idle.
Old Jan 14, 2004 | 10:47 AM
ED6's Avatar
ED6
Thanks for the reply. Theres a leak in that line which, since it controls idle, is probably what is causing the idle to be rough. Think I got it figured out now, thanks for the help.
Old Jan 14, 2004 | 12:01 PM
ED6's Avatar
ED6
Alright, I fixed the leak but it still idles like ****. It also doesnt rev past 3000rpm. Is it because the IAT sensor is unplugged? Will that cause it to do all this?
mitchh29
16
Mar 24, 2013 09:11 PM
qpzm12
May 23, 2011 04:30 PM
classciv
11
May 9, 2007 03:51 PM
folta2169
Apr 26, 2005 08:45 PM
tilt
Jan 2, 2004 02:54 PM
