wireing harness from zc to hf
KEEP YOUR HF HARNESS!!
you will have to re-pin the distributor,but its not big deal.. the colors will all match up execpt for two, blue green and blue yellow, you will have to take those two wires and hook them up to the sensor on the head.
you may want to use the distributor side connector and re-pin the distributor on the zc.
dont toss that HF distributor, all the internals are the same/compatible.
good luck
good luck
crxdriver89
Aug 8, 2005 10:45 AM
pyro_freak8
Mar 25, 2004 01:30 PM
