B18 Turbo and LS Parts for sale
Old Jan 13, 2004 | 02:30 PM
AllMotorGSR94's Avatar
Default B18 Turbo,GSR, and LS Parts for sale
I am cleaning out all my stuff. Got to make room for my LS/VTEC build up.
Here is List of things Im selling.
RC 310cc Injectors- had them in my NA setup, low miles on them - SOLD
Turbo Drag Manifold- Extreme Heat Black Paint Coated, Already tapped for EGT Gauge. In perfect condition. SOLD
Custom Turbo Intake Pipe- 2.5 Inch diameter. Heat Coated Black. $50
Custom made Downpipe- 2.5 inch diameter, had two welded o2 bungs. one for 02 and another for wideband. Also heat coated black. The two o2 bungs can be used if ODB2 to get rid of the cat converter- $75
LS Rods w/ Pistons- Sold
LS Intake- Removed from same motor as above. In excellent condition, removed from motor and cleaned. missing IAC $70
GSR Oil Pump - front main seal is still good, gear spins freely - $40
LS Oil Pump & pick up - removed from same LS motor as above, front main is in good shape. gear spins $30
GSR Valvetrain- Come out of my Integra GSR when I rebuilt it. I swapped out the entire valvetrain. It comes with VTEC Valves, Valvesprings (dual on intake side) and OEM retainers. sorry no cams... - $100
Make an offer on anything listed above.
Email for pics acura@nauticom.net
Thank you.
Modified by AllMotorGSR94 at 7:33 PM 1/27/2004
Modified by AllMotorGSR94 at 9:04 PM 1/27/2004
Modified by AllMotorGSR94 at 3:30 PM 1/28/2004
Modified by AllMotorGSR94 at 11:52 AM 2/6/2004
Modified by AllMotorGSR94 at 11:53 AM 2/6/2004
Old Jan 13, 2004 | 04:38 PM
91tegrals's Avatar
got any pics of the turbo...
Old Jan 13, 2004 | 06:21 PM
GahDamnGsr's Avatar
Default Re: (AllMotorGSR94)
Any pics of that 2.5 intake pipe? Does it have flange welded?
Old Jan 13, 2004 | 07:34 PM
Default Re: (B18c1Turbo)
heres the turbo intake pipe , correction its 2.75 inch
heres the downpipe. 2.5 inch.
Old Jan 13, 2004 | 08:11 PM
gots_a_sol's Avatar
how much for that manifold? pics?
Old Jan 13, 2004 | 08:31 PM
Default Re: (wants_a_sol)
heres a pic of the manifold.
Old Jan 13, 2004 | 10:05 PM
just added....
GSR Valvetrain- Valves, valvesprings (dual on intake side)and OEM retainers. In excellent condition, sorry no cams
Old Jan 14, 2004 | 06:24 PM
turbo manifold is sold
Old Jan 14, 2004 | 08:07 PM
bubblebackinSI's Avatar
do u have a distributor for sale
Old Jan 15, 2004 | 09:24 AM
just added LS ECU
Old Jan 15, 2004 | 10:08 AM
tegsol1's Avatar
intrested in the ls intake manifold how much
Old Jan 15, 2004 | 02:22 PM
more stuff added
Old Jan 15, 2004 | 02:28 PM
NobodySpecial's Avatar
Default Re: B18 Turbo,GSR, and LS Parts for sale (AllMotorGSR94)
how much for the downpipe? is it a/c friendly?
Old Jan 15, 2004 | 04:55 PM
I dont know to be honest, the car is was on before mine didnt have a/c to begin with
Old Jan 15, 2004 | 10:18 PM
just picked up a d16z6 gonna be parted soon as well, it has a bad crank (some *** busted the bolt end off while doing the time belt) it has 72,000 on it, 95 d16z6 no distributor. other than that its complete
Old Jan 16, 2004 | 05:15 AM
Si Integra's Avatar
How much for the downpipe and also the turbo
Aim me if you prefer to keep it private.
SiIntegra
Old Jan 18, 2004 | 09:38 PM
ttt
Old Jan 19, 2004 | 05:24 AM
Si Integra's Avatar
ok, i did not hear from you....?
Old Jan 19, 2004 | 08:16 AM
hmm I sent you an AOL IM , maybe for some reason it didnt go through... Ill try again sorry about that
Old Jan 20, 2004 | 07:07 AM
injectors are now sold
Old Jan 22, 2004 | 07:04 AM
bump
Old Jan 22, 2004 | 07:17 AM
mugenek007's Avatar
hey i just pmed you about the ecu
Old Jan 23, 2004 | 01:23 PM
you got it
Old Jan 23, 2004 | 06:25 PM
bump
Old Jan 23, 2004 | 06:32 PM
hondaeg8's Avatar
so the gsr oil pump is good right? nothing wrong with it? my oil pump may be going out and i will need another one.
