Are 88 DX hubs the same as 90 Si's?
My lug studs on my driver side are all stripped, and i cant put on lug nuts anymore.
I can get a 88 DX hub from a friend for like 10 bucks instead of going to the junk yark for 62 bucks, i was wondering if the 88 DX hub will fit my 90 Si Hub, and if it doesn't, is there a way to fix it yourself cause at the shop they want 25 dollars a stud, and thats a hundred. and the studs are only like 2.50, so they charging a lot for labor. Thanks.
90 Si Hatch Nitrous
92 Prelude pos Daily Driver.
90 Si Hatch Nitrous
that's the answer i was looing for haha....ok i have never been through this before but how the hell do you do it? just pound it out?...and for 10 dollars for a x hub i think is a deal lol.
From: I told you to wait in the truck in Texas, United States
As far as I know an 88 dx has a smaller size axle spline than an 89-91. So I don't think you can use them. That's the unfortunate part about 88's they were the wierd year.(axles/suspension/clutch, etc...) good luck
http://www.redeyefabrication.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redeyeef2 »</TD></TR><TR><TD CLASS="quote">As far as I know an 88 dx has a smaller size axle spline than an 89-91. So I don't think you can use them. That's the unfortunate part about 88's they were the wierd year.(axles/suspension/clutch, etc...) good luck
http://www.redeyefabrication.com </TD></TR></TABLE>
Really? I have a B16 swap in my 88dx crx and I kept my stock knuckles and hubs...
Every 88 dx I have ever done had small splines....
but 88 si has large spline.. then again I don't claim to be all knowing so oh well...
but 88 si has large spline.. then again I don't claim to be all knowing so oh well...http://www.redeyefabrication.com
all 88-91 Civic/CRX DX and Si have the same knuckles/hubs - all 88-91 Civic STD and CRX HF have the smaller knuckles/hubs
NO! You go to napa or autozone or what ever. Buy 4 replacement bolts for like $2.00 each. Remove your rotor, pound the old ones out, put the new ones in as best you can. When you tighten the lugs down, it will pull them in all the way.
Remember to torque to 94 ft/lbs.
shane4585
Feb 11, 2005 08:57 PM
Outsane
Mar 17, 2003 06:07 PM
