RUNNING FLAT!! WHAT TIRE PRESSURE!!
Old Sep 29, 2001 | 09:10 AM
RHGSR01's Avatar
New User
Default RUNNING FLAT!! WHAT TIRE PRESSURE!!
On my teg, Im running on some Kumho 205/40/17 tires and they look a little flat so im going to pump some air in them. The recommended tire pressure is 44 psi, Do ya think that I should pump it a little less then that like 42 or 44 psi or just pump it to 44 psi???
Old Sep 29, 2001 | 11:13 AM
nsxtcjr's Avatar
New User
Default Re: RUNNING FLAT!! WHAT TIRE PRESSURE!! (RHGSR01)
Since it's a GSR, why don't you ask on the Integra board instead of the Type R board?
Old Sep 29, 2001 | 02:10 PM
onyx00's Avatar
Default Re: RUNNING FLAT!! WHAT TIRE PRESSURE!! (nsxtcjr)
Good answer Ken
Old Sep 29, 2001 | 03:33 PM
Big Phat R's Avatar
44 is waay too high.
Old Sep 29, 2001 | 03:52 PM
EG8R's Avatar
Default Re: RUNNING FLAT!! WHAT TIRE PRESSURE!! (Big Phat R)
30-32 is good
Old Sep 29, 2001 | 08:42 PM
Bob#455's Avatar
Well, since they both have the same factory tire pressure recommendations, you could have just given him an answer .
The factory specs are 35 psi front/33 psi rear, which should be fine for normal driving conditions.
benji7288
Nov 21, 2007 01:21 PM
adrian1281
Jun 28, 2003 08:39 AM
MooreBoost
Sep 5, 2002 03:26 PM
skyline69
Jan 5, 2002 04:03 PM
RHGSR01
Sep 29, 2001 02:46 PM
