will 93-98 supra injectors work in OBD0 peak hold setups???
found some 93-98 550cc's for a good deal just wanted to know if they can fit into my 90 si which uses peak hold style injectors.. did anyone try this do they fit , currently have dsm blue top 450cc's so modding is ok if they fit and work , thanks for the info guys...
if they are peak and hold they should work, BUT they have to be top feed and NOT side feed.
also you may have to change the clip.
eidt: I believe the older ones from the mk3 might be a better bet.
Modified by twkdCD595 at 1:04 PM 1/13/2004
slow02ss camaro
Dec 9, 2003 04:02 PM
