ITR Seats Question
Old Jan 13, 2004 | 03:24 AM
Problemo's Avatar
Default ITR Seats Question
Hey folks, As I understand it the seats in the ITR are Recaro's but are they specificaly made for the ITR or are they a re-trim of a standard Recaro off the shelf seat, I've seen similar looking before but never side by side in real life.
Thanks for your help folks.
- Prob
Old Jan 13, 2004 | 04:02 AM
Philly_NBP_R's Avatar
Default Re: ITR Seats Question (Problemo)
Do a search...
USDM seats are NOT Recaros. They are modified versions of the GSR seat (covered in Alcantara, bigger bolsters, softer bottom cushion). JDM R seats are very nice Recaros - similar to the SRD I believe...
Old Jan 13, 2004 | 07:15 AM
Mugen Mike's Avatar
Default Re: ITR Seats Question (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">Do a search...
USDM seats are NOT Recaros. They are modified versions of the GSR seat (covered in Alcantara, bigger bolsters, softer bottom cushion). JDM R seats are very nice Recaros - similar to the SRD I believe...</TD></TR></TABLE>
I believe they are still manufactured by Recaro, but maybe I'm wrong -- anyone??
Old Jan 13, 2004 | 07:17 AM
Kicker773's Avatar
Default Re: ITR Seats Question (Mugen Mike)
dont forget the center piece is there on the usdm's n not present on the jdm ones. i believe you have to so some sort of modification in order for the jdm one to fit onto a usdm itr. correct me if i'm wrong.
Old Jan 13, 2004 | 07:19 AM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">
I believe they are still manufactured by Recaro, but maybe I'm wrong -- anyone??</TD></TR></TABLE>
which ones?US or Jap?the JDM ones ARE manufactured by Recaro,the US are NOT.
chris
Old Jan 13, 2004 | 07:20 AM
Mugen Mike's Avatar
Default Re: ITR Seats Question (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
chris</TD></TR></TABLE>
I was refering to the US seats. I remember my old EF Si seats were manufactured
by Recaro *shrug*
Old Jan 13, 2004 | 07:22 AM
Mugen Mike's Avatar
Default Re: ITR Seats Question (Kicker773)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">dont forget the center piece is there on the usdm's n not present on the jdm ones. i believe you have to so some sort of modification in order for the jdm one to fit onto a usdm itr. correct me if i'm wrong.</TD></TR></TABLE>
No modifications neccessary, you just won't be able to access the seat-back adjusters with the armrest in place -- you'd have to open the door and adjust them from the outside part of the seat.
Old Jan 13, 2004 | 11:14 AM
markpaco's Avatar
No modifications neccessary, you just won't be able to access the seat-back adjusters with the armrest in place -- you'd have to open the door and adjust them from the outside part of the seat.</TD></TR></TABLE>
The JDM recaros only have the rake adjustment on one side whereas the Recaro SRDs have them on both sides. What you need to do to install a JDM Recaro while still retaining the center console is to put the RH seat on the LH and vice versa so you get the rake adjuster on the outside of the seat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Are you talking about the rear seats? If so, I believe that is true.
Wh
Old Jan 13, 2004 | 12:44 PM
gsr-2nr's Avatar
Default Re: ITR Seats Question (markpaco)
[QUOTE=markpaco]
The JDM recaros only have the rake adjustment on one side whereas the Recaro SRDs have them on both sides. What you need to do to install a JDM Recaro while still retaining the center console is to put the RH seat on the LH and vice versa so you get the rake adjuster on the outside of the seat.[QUOTE]
or you can put them normally and just go out and buy a jdm center console
i still have my usdm console with my recaros i have it set to the way i want it so no need to further adjust them
Old Jan 13, 2004 | 03:47 PM
Kicker773's Avatar
i was talkn about the rear seats...
Old Jan 13, 2004 | 07:14 PM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">i was talkn about the rear seats...</TD></TR></TABLE>
My bad, you never specified.
Old Jan 13, 2004 | 09:37 PM
98cwitr's Avatar
JDM ITR recaro's have got to be the most comfortable seats i have ever sat in...they just hold you like a glove. Only if i had $1300. as far as the rear seats...IMHO they are a waste of money
Old Jan 14, 2004 | 01:25 AM
ALLMOTR_R's Avatar
AUSDM get JDM Recaro's standard.
Pretty much an identicle set up as JDM interior wise, except for the 180km speedo.
Old Jan 14, 2004 | 06:24 PM
Punkaddic's Avatar
concept by recaro but not made by recaro
Colin00
Honda Civic (2006 - 2015)
16
Nov 12, 2010 01:05 PM
street_of_rage
May 13, 2009 06:41 AM
petrv
Aug 3, 2004 12:57 AM
Jdmbsixteen
Mar 3, 2004 11:49 AM
LOwrestling2001
Apr 26, 2002 07:36 AM
