88 Civic Dx?
Old Jan 13, 2004 | 01:57 AM
Salvatiosix's Avatar
Default 88 Civic Dx?
Heres the story, I got my moms 88 civic dx, 5 speed, thats pretty much all i know about it. I know it has a fuel leak, in the fuel line, the clutch "could" be going, and the engine kinda idles funny, higher then lower then higher, then lower.
My questions are, whats the engine(specs)? How expensive and hard to replace would the fuel line be? what could be wrong with the engine idle?Would it be worth it to fix it? and my dad said you have to pull the engine to change the clutch, Are new clutchs expensive and is it a hard process to pull the engine and change the clutch and such.
Sorry for the newbie questions, but no one else up to this point has been able to answer them.
Thank you
-Shaun
Old Jan 13, 2004 | 04:44 AM
tpr's Avatar
tpr
Default Re: 88 Civic Dx? (Salvatiosix)
The idle problem could be a vacuum leak or TPS (Throttle Position Sensor) going bad. As far as the clutch replacement you do not have to pull the motor to change out the clutch. What makes you think its going bad? Have you adjusted the free play? I have an 88 DX that I have swapped a DOHC ZC into it is fun to drive and still gets 30-32 MPG. Does the car have any rust? If not it makes a good platform for many modifications. Its the second lights of that series only the HF s lighter.
Old Jan 13, 2004 | 06:24 AM
rsbad454's Avatar
Default Re: 88 Civic Dx? (tpr)
could be your IACV going back........that will make it idle up and down.....
Old Jan 13, 2004 | 10:21 AM
EL Vap133's Avatar
A clutch will not be expensive for a stock dx, you only need to pull the tranny out to change it.
Old Jan 13, 2004 | 03:37 PM
UPS's Avatar
UPS
Welcome to H-T
Sounds like you got some bugs to work out but it shod be cheep to fix good luck.
Old Jan 13, 2004 | 03:40 PM
90JPRCRX's Avatar
Smells like Tuna
Default Re: 88 Civic Dx? (UPS)
wow im proud of you guys
4 posts at a n00b with legit questions and nobody is running for their flame retard suits
congrats H-T
Old Jan 13, 2004 | 09:52 PM
Default Re: 88 Civic Dx? (88JPRCRX)
Thanks alot guys!
jdav
Apr 23, 2008 09:35 PM
Mr. Roboto
Oct 28, 2006 11:31 AM
Civiclized
Mar 17, 2006 02:15 PM
Sleeper180sx
Apr 29, 2004 10:40 AM
91teg
Feb 20, 2004 03:32 AM
