Has any bolt every backed out on u before?
Old Jan 13, 2004 | 01:12 AM
david90's Avatar
Default Has any bolt every backed out on u before?
I just did my timing belt and water pump and didn't use thread locker on any of the bolts. Should I be worry? how often do bolts back out? I did torque everything down nice and tight
Old Jan 13, 2004 | 05:07 AM
trbob16a's Avatar
Default Re: Has any bolt every backed out on u before? (david90)
If you torqued them you're fine.
Old Jan 14, 2004 | 09:56 PM
david90's Avatar
Default Re: Has any bolt every backed out on u before? (trbob16a)
I didn't actually torqued it to specs because torq wrench was too big. I did take the specs into consideration and estimate with F*d= torque. hopes it is ok.
Old Jan 15, 2004 | 05:35 AM
rapid_roy's Avatar
My right side engine mount bolt backed almost all the way before I caught it. As far as I know it has never been taken out or lossened.
Cheers,
Sean
Old Jan 15, 2004 | 10:05 AM
senpai's Avatar
Those bolts you speak of need only like 8-9lbs of torque...
Old Jan 15, 2004 | 02:09 PM
ultimatehonda's Avatar
If you tq them good then u should be good.......
Old Jan 15, 2004 | 02:33 PM
sivik2nr's Avatar
Once one of my engine mount bolts backed out all the way on me. Maybe it's because taht's the only one that wasn't OEM...
D16SohcVtec
Jun 4, 2008 03:52 AM
grngsr01
Aug 24, 2005 09:18 AM
SurferX
Mar 4, 2003 07:38 PM
Madracer1
10
Dec 19, 2002 01:49 PM
