FS Built B18b Short Block
I have a B18b complete short block for sale.
Golden Eagle Sleeves
Eagle Rods
Arias Pistons 84mm 9.1cpr
Stock crank.
Block is complete with water pump oil pump, oil pan,
Block has 5k on it was removed because of oil comsumtion. Main and Rod bearings were replaced during build using only OEM Acura parts.
sleeves are not damaged nor is the rods and bearings.
1000.00 Firm + shipping NO trades unless u have a NEW pt71.
Pics below
Eagle Rods
Stock crank.
Pics below
i would assume the rings. i bet just get it bored next step over and run some new pistons and you should be fine. i also wondering since it seems to be local person for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">i would assume the rings. i bet just get it bored next step over and run some new pistons and you should be fine. i also wondering since it seems to be local person for me</TD></TR></TABLE>
84mm is already quite a big bore!!
new rings should only require a hone unless there is damage to the walls...
if you had this forsale about 8 months ago, i would've bought the friggen bajesus out of this, instead i had to byu a sleeved block for 600, rods for 300, pistons for 400, rings for 70, bearings for 100, blah blah blah
-Ryan
ps - great price, it should sell fast!
-Ryan
Chrome Pipes
Mar 7, 2017 02:33 PM
AIM me IM call me I don't care
