Gauge Color Change
Old Jan 12, 2004 | 03:38 PM
JDMVTEC's Avatar
Default Gauge Color Change
Is there any way I could change the tach, speedo,temp, and gas gauge that light up blue in my 94 VTEC so they will al light up amber?
Old Jan 12, 2004 | 08:05 PM
xALL MOTORx's Avatar
Default Re: Gauge Color Change (JDMVTEC)
paint the bulbs
Old Jan 12, 2004 | 08:22 PM
Anhjockz's Avatar
you want them amber right well there a way to do it.......
https://honda-tech.com/zerothread?id=640042
this is how to make it blue but its the same way just change the flim color thats alll
and you need to know how to make amber from green
so hope it works for you
Old Jan 12, 2004 | 08:23 PM
munscher's Avatar
It should be possible... the normal choice is blue, which is in fact easier since its not far off from the stock color. If you wanted to go amber, you would have to remove the greenish-blue tinted lens from in front of the fuel/temp gauges and also you would have to scratch off some of the backing on the speedo/tach face insert. Other than that it would be the same process but with a different tinting.
Case in point...
Old Jan 12, 2004 | 11:33 PM
dankbudz11357's Avatar
Default Re: Gauge Color Change (munscher)
thinking of doing this mod too. has a nice clean look and it seems like it's not too hard to do
Old Jan 13, 2004 | 03:25 AM
NAR Cd7 Lude
Guest
Posts: n/a
change the bulb to the desired color
Old Jan 13, 2004 | 06:07 AM
Sephro's Avatar
Default Re: Gauge Color Change (NAR Cd7 Lude)
I don't see how you could get them to light up amber... I am not too sure how the VTEC tach/speedo are setup... but the gas/fuel Gage is indigo... this would have to be swapped out with something else because no color mixed with blue makes amber correct.... You have to look at the good ol color wheel to see the colors that you can make it simply by applying a film over. You can change bulbs out for LED's but IIRC there is no amber color LED.. but you could use filters on bulbs... Hope that gives you some insight.
Old Jan 13, 2004 | 06:09 AM
cecknight's Avatar
Default Re: Gauge Color Change (Sephro)
If you want blue, do'nt you have to take the needles and face off to put that blue plastic in?
Old Jan 13, 2004 | 06:12 AM
Sephro's Avatar
Default Re: Gauge Color Change (cecknight)
I wouldn't even screw aroun with the film on anything other than the fuel/temp gage.. Just swap the bulbs out for LED's Much better color IMO..
Old Jan 13, 2004 | 02:34 PM
munscher's Avatar
the needles do not have to come off of the speedo/tach, but the face does. It's not too terribly hard though.
Old Jan 13, 2004 | 03:37 PM
JDMVTEC's Avatar
I like the blue color but it seems like alot more work than I want. Im not very good with patience on little jobs like that.
Old Jan 13, 2004 | 08:52 PM
rluder21's Avatar
Default Re: (JDMVTEC)
Would this same mod work for 5th gens?
Thanks!
Old Jan 13, 2004 | 09:08 PM
ef93si's Avatar
you would probably have to put custom LED's behind there, because 5th gens do not have the EL gauges...
Old Jan 14, 2004 | 03:27 AM
prelude1897's Avatar
Default Re: (rluder21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rluder21 &raquo;</TD></TR><TR><TD CLASS="quote">Would this same mod work for 5th gens?
Thanks!</TD></TR></TABLE>
You'll have to use LED bulbs....There is a write-up on http://www.hpoa.org I believe
Old Jan 14, 2004 | 05:32 AM
Nick M's Avatar
the rice forum is alittle farther down the page
Ripcord990
Jan 11, 2014 04:06 PM
liquidice17
Honda Civic (2006 - 2015)
Sep 26, 2007 03:06 PM
eluder33
Aug 20, 2004 09:31 AM
azian21485
Jul 16, 2003 01:00 PM
tuco_ruiz
Jun 1, 2003 09:10 AM
