fuel line d-series/b-series
Old Jan 12, 2004 | 02:20 PM
highschooler's Avatar
Default fuel line d-series/b-series
I am just about done with the b18b swap int a 92 dx hatch, and I came to the fuel line. it looks like the stock civic fuel line has the opening on the bottom, and where it is supposed to connect to the motor, the opening is on the side of the fuel rail. It looks like they aren't compatible, yet I have never heard anything about changing the fuel line when you swap. will the stock civic line work, or do I need to get an integra one?
Old Jan 12, 2004 | 02:24 PM
egsleepercivic's Avatar
stock line should work just fine
I used the stock line when I swapped my JDM b16 into my 94 ex
Old Jan 12, 2004 | 02:31 PM
Default Re: (egsleepercivic)
alright, you didnt have to change the fuel rail on the new engine, or change the old fuel line? did you just put it directly on?
Old Jan 13, 2004 | 05:49 AM
doublejz's Avatar
Default Re: (highschooler)
nope, everything should fit right on. It did in my 93 eg. Are you talking about the banjo bolts that go on the fuel rail and on the fuel filter?
Old Jan 13, 2004 | 07:11 PM
original_j's Avatar
Default Re: fuel line d-series/b-series (highschooler)
from what i know dx fuel line banjo fitting is smaller than ex and youll need to get a ex fuel line in order to make it fit, just my two cents
eddie7978
33
Apr 5, 2018 08:50 PM
skunk2powered
Oct 17, 2005 04:01 PM
Race Egr
Mar 7, 2004 10:08 AM
WhatThaFrig
Feb 23, 2003 11:23 AM
blackANESE
Jul 5, 2002 04:59 AM
