Difference: GSR vs. ITR spindle
You would need calipers too correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by visi0n »</TD></TR><TR><TD CLASS="quote">EHHH? so you can just buy the hub to convert your junk to 5lug?
wtf!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D »</TD></TR><TR><TD CLASS="quote">spindel/knuckle is the same.
D</TD></TR></TABLE> I think you are wrong. I believe the 5 lug spindle is larger than the 4 lug spindle. the 5 lug hub is larger and thus requires a laarger spindle into which it will seat.
also think about it... if converting to 5 lug was as easy as swapping out a pair of $100 hubs from Acura and new rotors/calipers, not requiring the $800+ complete assemblies, dont you think everyone would rock 5 lug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR »</TD></TR><TR><TD CLASS="quote">The spindle is the same. Part numbers are the same. You need more than just the hub for a 5 lug conversion.</TD></TR></TABLE>
I'd guess its something like this if they truely do fit.....
Per Corner:
Hub
Caliper
Bracket
5x studs
Wheel
Extra lugnut
Per Corner:
Hub
Caliper
Bracket
5x studs
Wheel
Extra lugnut
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">
Per Corner:
Hub
Caliper
Bracket
5x studs
Wheel
Extra lugnut
no rotors?
Per Corner:
Hub
Caliper
Bracket
5x studs
Wheel
Extra lugnut
no rotors?
no rotors?
Pffft. rotors... I'm running the new JDM rotorless system.... it roxors...
no rotors?
</TD></TR></TABLE>Pffft. rotors... I'm running the new JDM rotorless system.... it roxors...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">Pffft. rotors... I'm running the new JDM rotorless system.... it roxors...</TD></TR></TABLE>
LOL. Maybe that is why you can't drive in the snow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy »</TD></TR><TR><TD CLASS="quote"> I think you are wrong. I believe the 5 lug spindle is larger than the 4 lug spindle. the 5 lug hub is larger and thus requires a laarger spindle into which it will seat.
yeah, you're right, i have no ******* clue what i'm talking about. i've never bent any of these and replaced them in the 125k worth of use... sigh...
