Cutting carbon fiber
Old Jan 12, 2004 | 11:01 AM
travis's Avatar
Default Cutting carbon fiber
I'm working with a 0.032" sheet of CF that I need to cut (both straight and curved cuts). If it were any thinner, I would use an x-acto knife, and if it were any thicker I would use a jig saw. However, I'm not sure how it will hold up to a jig saw at this thickness. Anyone know a good tool or technique to cut CF?
Old Jan 12, 2004 | 11:33 AM
onePOINTsix's Avatar
Default Re: Cutting carbon fiber (travis)
i'd use a very light touch with a cutoff wheel and some air tools
Old Jan 12, 2004 | 12:58 PM
doublejz's Avatar
Default Re: Cutting carbon fiber (Sideout)
an electric portable band saw
Old Jan 12, 2004 | 02:13 PM
99spanishGT
Guest
Posts: n/a
Default Re: Cutting carbon fiber (doublejz)
go with the roto zip!!!
Old Jan 12, 2004 | 02:24 PM
rtype11's Avatar
garden clippers from gardena will cut it
Old Jan 12, 2004 | 11:25 PM
WCI's Avatar
WCI
Default Re: Cutting carbon fiber (rtype11)
cutting disk 4 sure
Old Jan 13, 2004 | 01:57 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Cutting carbon fiber (WCI)
Just make sure you wear a mask so you dont breathe the carbon in your lungs. That stuff is very bad for you!!
art
Old Jan 13, 2004 | 04:16 PM
Sobe_Death's Avatar
kinda like smoking menthol cigarettes, only no smoke!
Old Jan 13, 2004 | 04:24 PM
Kendall's Avatar
I've had a lot of success using a dremel. The various tools allow pretty much any cut, as well as the ability to slowly work at something to reduce mistakes.
Old Jan 13, 2004 | 04:26 PM
Kamin's Avatar
Default Re: (Kendall)
slow steady hand with a dremel.
Old Jan 13, 2004 | 04:27 PM
HNDAPWR's Avatar
Put masking tape down first, and draw your lines on that. The x-acto trick works good, just do it many times over.
Old Jan 13, 2004 | 04:29 PM
Kendall's Avatar
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">slow steady hand with a dremel.</TD></TR></TABLE>
Yes, indeed.
I think it would depend more upon the size of the cut. If you were trying to fill in a window, then a cutoff wheel would probably work the best, but for small interior pieces, definately the dremel.
Old Jan 13, 2004 | 04:41 PM
travis's Avatar
Default Re: (HNDAPWR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HNDAPWR &raquo;</TD></TR><TR><TD CLASS="quote">Put masking tape down first, and draw your lines on that. The x-acto trick works good, just do it many times over.</TD></TR></TABLE>
Do you think I could get through 0.032" with the x-acto?
As for the dremel, I was looking at dremel bits today to see if there was something I thought would work well. What do you suggest? Just a standard cutting wheel? There's a lot of dremel parts I have never used since I mostly use the dremel for metal work. I need to cut holes for switches and gauges, so some of it will be a little difficult. Thanks for the help.
Old Jan 13, 2004 | 04:43 PM
Kendall's Avatar
Default Re: (travis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis &raquo;</TD></TR><TR><TD CLASS="quote">As for the dremel, I was looking at dremel bits today to see if there was something I thought would work well. What do you suggest? Just a standard cutting wheel? There's a lot of dremel parts I have never used since I mostly use the dremel for metal work. I need to cut holes for switches and gauges, so some of it will be a little difficult. Thanks for the help.</TD></TR></TABLE>
The standard cutting wheel should work fine.
Old Jan 13, 2004 | 06:03 PM
Kamin's Avatar
ill verify, yes it does.
getting **** ready for AMP this weekend bro? i wont be there because ill be in tucson finishing up my 240.
Old Jan 13, 2004 | 06:29 PM
travis's Avatar
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">ill verify, yes it does.
getting **** ready for AMP this weekend bro? i wont be there because ill be in tucson finishing up my 240.</TD></TR></TABLE>
Yea, getting ready for the AZ Honda-Challenge points season opener. You should see the car...lots of new toys. The CF is for a simple dash panel for the start button, the gauges, and a few switches for fans and the transponder. I don't think I can cut holes for the gauges with a cutting wheel. Those aren't good for tight radius turns. Is there something better for that? Beyond cutting wheels and grinders, I'm not really familiar with dremel bits. Something that works like a tile cutter might be nice (like a drill bit, but it cuts sideways), but I don't know if that's the right tool for CF.
Old Jan 13, 2004 | 06:55 PM
Kamin's Avatar
AZ HONDA CHALLENGE?! WHAT THE ****
if i would have known there was gonna be a AZHC after all that damn time i spent working on the WCHC i would have gotten a CRX instead of the 240 to race.
god damnit.
but yea i wanna see all the goodies on the race kaa, next event there is, ill be there. probably spectating cause i cant afford new tires
Freemananana
Paint and Body
Sep 10, 2014 04:58 AM
Greyout
Welding / Fabrication
14
Aug 12, 2012 08:55 AM
85
May 19, 2005 10:21 AM
dustywebber
May 2, 2004 04:56 PM
dustywebber
May 1, 2004 06:52 PM
